R55 no throttle response, red engine light
Old Oct 6, 2022 | 04:56 AM
chinafrank's Avatar
chinafrank
After starting no throttle response. Orange engine light steady on.
Restart engine and all was OK. This problem continued occasionally.
But meanwhile red engine light is steady on plus the service light.
Error Code ISTA 2BE4 with 3 hits:
1) DME internal fault.
2) Pressure Sensor before throttle valve.
3) Low fuel pressure operating range: Pressure too high
Restarting a couple of times help, if throttle response, yellow engine light comes back on.
Can somebody guide me? There is no Mini repair here on that small island in the Philippines..... (the island calls Panglao)
Old Oct 16, 2022 | 09:52 PM
keduMINI's Avatar
keduMINI
Is this Clubman a turbo?
If yes, check the turbo wastegate linkage for looseness (i.e., a worn hinge) and check the connections of the vacuum tubing routed from the mechanical vacuum pump through the vacuum box below the throttle body and ending at the wastegate vacuum inlet. Either of these could cause intermittent 1/2 engine light issues.
Old Oct 21, 2022 | 03:42 AM
chinafrank's Avatar
chinafrank
Thank you for your reply.
No its not a turbo. sometimes half engine light in orange, sometimes full orange, sometimes red engine light..... I am baffled.
computerdoc
May 15, 2019 08:14 PM
CubanoPete
Jan 9, 2013 08:57 AM
surfin'02
Jan 22, 2012 08:32 PM
dkamp
R55 :: Clubman Talk (2008+)
Nov 23, 2011 07:44 PM
Ranzo
Apr 13, 2007 08:19 PM
