Oil Change on GP3?
Old Aug 19, 2022 | 07:58 AM
Hellokitty90's Avatar
Hellokitty90
Oil Change on GP3?
I can’t seem to find anything related to this anywhere.
1) Does the GP3 take 5.5 quarts / 5.2L of oil?
2) Is there anything more difficult about the GP3 oil change? I saw some videos that the filter can only be accessed from the bottom of the car, seems easy to get to unless I’m missing something about additional bracing on GP3 specific cars.
3) Manual calls for LL17-FE. I am considering using LL-01FE as a recommended substitute per the manual (0w-30) for some additional HTHS protection. Do you guys agree?
Old Aug 23, 2022 | 06:07 AM
benben01's Avatar
benben01
Interested as well. Read somewhere you had to loosen the top engine mount to tilt it back so the filter housing is accessbile. Is that right?
Old Aug 24, 2022 | 07:08 AM
Hellokitty90
I went to the Mini parts counter and pulled data for my GP3 with its VIN.
The oil fill is 5.75L.
Still not sure about the oil filter position, but I’ll get under the car next week to find out.
I ordered Mini 0w-30 (LL-01FE) and a filter from FCP Euro.
Old Aug 24, 2022 | 08:06 AM
benben01's Avatar
benben01
Thanks for the info. I was going to go with maybe 5-40 Liqui Moly as I do with all my cars and MOS2 additive for anti-friction. With this car not being so much of a daily driver, will try and keep oil changes to 5K or every 6 mos.
Old Aug 24, 2022 | 10:15 AM
TVPostSound's Avatar
TVPostSound
Why 5-40, when the engine tolerances specify 0-30?
Thicker oil can starve tight tolerance engine parts.
This is the recommend Liquid Moly for yours
https://products.liqui-moly.us/top-t...e-0w-20-5.html
Stick with LL17-FE, ECS carries it at a reasonable cost.
Old Aug 24, 2022 | 10:40 AM
benben01's Avatar
benben01
The same reason why I don't run 0-30W on my BMW X5M. The difference of 30W vs 40W is not significant with tolerances of modern engine. I rather have the extra protection and film strength especially in a high pressured turbo motor from a 40W oil vs 30W oil. The use of lighter weight oil by all the manufacturer today is mainly for boosting MPGs to achieve EPA mandates. I can be convinced otherwise with this 4-banger
Old Aug 24, 2022 | 11:01 AM
Hellokitty90
I am only going with LL01-FE 0W-30 as it if specifically stated in the manual as acceptable to use. Since my GP3 is stock, I think it will offer balanced protection for my hard driving (HTHS of 3.4 compared to 2.8 with LL17-FE) without killing fuel economy.
I use LL-01 5W-40 on my 2 other BMW inline-6 engines, which are both tuned.
Old Aug 24, 2022 | 11:26 AM
TVPostSound
Thinner oil = faster velocity especially through a turbo, oil gets in lubricates, cools, and leaves faster.
Higher pressure and viscosity is NOT essential, it actually slows down.
Old Aug 24, 2022 | 12:00 PM
benben01's Avatar
benben01
Thin and thick to a certain point where it provides the most amount of protection. Oil is like religion in the car world. We all have our experiences and preferences even in the face of empirical data. That being said, even empirical data is hard to sift through with the amount of caveats and controls. For the past decade and change, I've been running 0-40w and 5-40W in all my cars from V-TEC Hondas to Porsche GT3/4 and everything in between. All have performed flawlessly without issues.
Old Aug 24, 2022 | 02:22 PM
TVPostSound
It IS a religion to some.
I personally have bumped mine from recommended 0-20 to 0-30 only due to every day as been hitting 100+ degrees for the last 2 months.
Old Aug 24, 2022 | 06:06 PM
benben01's Avatar
benben01
So back to the question. Does one need to loosen top engine mount for a DIY oil change ?
Old Aug 30, 2022 | 08:23 AM
Should be the same, talked about oil and the changes here on the filter. I would jack it up and open the bottom little door and see were that filter sets. I have not done a change on the GP3 yet so i could not help on that.
https://www.northamericanmotoring.co...-question.html
Old Aug 30, 2022 | 09:19 AM
benben01's Avatar
benben01
Is this the correct filter? Didn't see a GP specific listing under submodel and only JCW. Also, what is the correct engine code for the the GP3? thx!
https://www.ecstuning.com/b-hengst-p...428593186~hen/
Old Aug 30, 2022 | 09:20 AM
Hellokitty90
The GP3 oil filter part number is: 11428593186
Old Aug 30, 2022 | 09:42 AM
beat me to it, yes. In our drop down we dont call out the GP3 as on MINI etk the only one called out is the GP1 for back in the day.
Just use the 2021 F56 JCW and look for the parts called out for the GP3 in red.
Old Aug 30, 2022 | 09:59 AM
benben01's Avatar
benben01
@Hellokitty90 Let's see some pics of the "heavily" modded F80
Old Sep 1, 2022 | 10:40 PM
Hellokitty90
Just finished the an oil change on the GP3. Some things to note:
1) 5.75L is the factory full amount per my service advisor. I used Mini 0w-30 LL-01FE oil.
2) The drain plug is located on the passenger side of the car.
3) There is no engine under tray.
4) You’ll need to remove the half under tray with 8mm screw (7 in total).
5) You will need a T45 torx to unscrew the drain plug under the filter housing before removing the housing.
6) You will need a 32mm oil filter socket to remove the housing and filter.
7) There is additional bracing specific to the GP3 (I believe) that gets in the way of the filter hosing just dropping down vertically. There are also some wires around the filter housing. You will need to unscrew the housing completely then angle the housing toward the passenger side then carefully remove the housing. You’ll reinstall at the same angle you came in (from the passenger side).
Pretty easy job overall.
Old Sep 2, 2022 | 02:35 AM
benben01's Avatar
benben01
Thanks for the the update. I will be changing the oil this weekend as well with the oil/filter kit from ECS along with X-Pel PPF on the front end and ceramic coating.
Old Sep 2, 2022 | 07:30 PM
Hellokitty90
Dont have any current pics but these arrived this week for it
Old Sep 3, 2022 | 03:22 AM
benben01's Avatar
benben01
BBS FI-R Moar pics!!!!
Old Sep 19, 2022 | 05:52 AM
benben01's Avatar
benben01
Just performed an oil change on the GP this weekend. Just like @Hellokitty90 mentioned, it's really straight forward and the oil filter/housing wasn't much of a challenge. Just angle it towards the passenger side and it comes right out with relative ease. I went with LM 5W-40 and a can of MOS2 anti-friction additive. Wife's feedback on driving after the oil change was the GP felt super smooth and noticeably quieter compared to the OE oil that had only 700 miles on it.
Old Sep 23, 2022 | 09:29 PM
dbturbo2's Avatar
dbturbo2
Did you ever get your wheels installed?
Old Sep 23, 2022 | 11:32 PM
Hellokitty90
not yet. spent last weekend doing 2 layers of ceramic coating on them.
I just need to mount them with tires then get some new wheel studs and lug nuts. I’m taking my time on this since I’ve been too busy at work these days. things won’t cool off until at least another 3-4 weeks :/
Old Sep 28, 2022 | 04:23 AM
benben01's Avatar
benben01
dumb question... curious to know what this drain looking this is.. always paranoid about going bumps and getting it damaged..
Old Sep 28, 2022 | 06:31 AM
RichsMINI's Avatar
RichsMINI
@benben01, I was told by a Service Advisor it was an drain line for the air conditioning…
After speaking with a MINI Technician it turns out to be the turbo air discharge duct and the part number is 11658605502
Locally there are some large speed bumps I’ve driven over and that part is not damaged.
Rich
