R50/53 Cooper r50 2006 miss communicating
Old Aug 3, 2022 | 10:24 AM
kevin1's Avatar
kevin1
Hi everyone,
I've been trying to search out this problem but I can't seem to find anyone who has had all the symptoms I'm having at the same time. So I have a 2006 base Mini Cooper and the EP light continues to flash on and off and when this happens the car randomly shifts gears and most of the time it seems to down shift because the RPMs go up. On top of that the temperature gauge needle will go all the way to the top as if indicating the car is overheating though it is not. Also the tachometer and all the lights on it (check engine and brake) will go completely dead. The speedometer will also die too. Also a number of warning lights will come on and some seem to stay on permanently, like tire pressure sensor, while others just flash on temporarily. This happens for a couple seconds at a time and then things just go back to normal, but things like the check engine light and tire pressure light stay on. This used to be a sporadic occurrence, but now I can't even drive the car because it just keeps bucking so much from the random shifting it's doing. It's almost like the car is possessed. Has anyone ever encountered anything like this. Thanks
Old Aug 3, 2022 | 07:31 PM
adriancl's Avatar
adriancl
I advice to check first the TCM -transmission control module-connector.
SkuzzillButt
MINI Camera and Video
Mar 10, 2024 01:51 AM
cleung
Dec 13, 2019 08:38 PM
phh06
Nov 23, 2017 03:06 PM
italchef
Electrical
Feb 18, 2013 07:55 PM
chad1140
Electrical
Mar 25, 2008 06:14 PM
