R50/53 ATI damper installation: do I care about TDC?
Old Jul 31, 2022 | 12:51 PM
Nervos's Avatar
Nervos
ATI damper has TDC and timing marks, but there is nothing (?) those marks can be checked against on the oil pump/timing cover. Sure I can put the engine to TDC (even, tho, it is a bit tricky without removing valve cover), install the damper and scratch my own mark on the oil pump / timing cover (so, it could be helpful (?) for finding TDC next time). Do people do this or nobody bothers?
Old Jul 31, 2022 | 01:03 PM
The Devil Z's Avatar
The Devil Z
not needed. No external timing marks or need for them.
Old Jul 31, 2022 | 01:06 PM
BlwnAway's Avatar
BlwnAway
Since its a simple press fit with no key way, doesn't matter at all.
Honestly the only things to deal with in the install is that you use an install tool and have a way to hold everything for proper torque on the bolt.
Old Jul 31, 2022 | 01:16 PM
Nervos's Avatar
Nervos
Yeah, I do have experience removing / installing the OEM damper (here is a photo of OEM damper installation, 2nd photo in the carousel:
View this post on Instagram
I should have installed the ATI damper at the beginning, but decided to save, since the OEM damper looked fine to me. Now I am trying to solve vibration issue at idle (no vacuum leak, afaik, STFT is good, belt tensioner is new, all eng / tranny mounts are new) and the vibration damper is my last resort.
Old Jul 31, 2022 | 06:58 PM
cooper48's Avatar
cooper48
Your vibration issue is most likely caused by faulty engine mounts (and/or solid mounts, i.e., poly). The ATI damper contains a high-viscous fluid that self balances when turning but I don't imagine that it will do much at idle since your RPMs are at a slow ~850.
Old Aug 1, 2022 | 11:17 AM
Nervos's Avatar
Nervos
You are probably right. The mounts are new, but the upper mount is aftermarket one and maybe it doesn't work like OEM. I think, I'll replace it first. But I still will replace the damper, just because
AndrewVanis
May 22, 2023 06:14 AM
shrevemini
Jan 12, 2021 04:32 PM
Scott Harrison
14
Dec 17, 2018 05:46 AM
plasticknives
May 27, 2016 05:22 AM
Marktheman
Sep 6, 2015 06:15 PM
