JCW My new 2023 JCW
Old Jul 25, 2022 | 08:34 PM
hotchicken's Avatar
hotchicken
My new 2023 JCW
Got her ceramic coated, PPF on the front, Eventuri scoop/intake, tint, a bit of wrap, and new wheels & tires.
Gotta deal with the wheel gap and lack of exhaust volume!
Old Jul 26, 2022 | 06:07 AM
CR&PW&JB's Avatar
CR&PW&JB
Looks great! Congrats!!
Old Oct 23, 2022 | 11:38 AM
hp_therapy's Avatar
hp_therapy
How do you like your Eventuri scoop/intake? I just picked up my JCW Convertible from Mini of Nashville and the modifications have begun.
Old Oct 23, 2022 | 12:15 PM
hotchicken's Avatar
hotchicken
I like it, but I probably only drove the car 10 miles before I put it on so I can’t compare. The one thing I’ve done that I think made the most interesting difference was installing the forge hard pipe. My gas mileage has improved by 4 MPG since installing it.
You’ll have a hard time finding any manufacturer that will promise their stuff fits anything beyond a 2020. However, the exhaust from Remus fit 100% and the downpipe went on with one tweak. Cut off the mounting bracket which has apparently moved. The manufacturer recommended it, and the mechanic said it was fine. Mounts up very strongly to the turbo, and is lighter than stock, so zero wiggle, even without the bracket.
Mod away! Sounds like we’re neighbors, so let me know if you have any questions or need help with anything.
Old Oct 23, 2022 | 12:22 PM
hp_therapy's Avatar
hp_therapy
Will send you a note, would love more info on your build.
Old Oct 23, 2022 | 01:09 PM
michaelo's Avatar
michaelo
Wheel gap looks fine to me. I would leave it alone. Once you start messing around with the suspension, you will start to get clunks and wheel alignment issues that are very annoying to deal with.
Old Oct 23, 2022 | 01:36 PM
CooperS56's Avatar
CooperS56
It’s a lot of money , 1k for very minimal return….looks good but better aftermarket ones for 75%less cost and do the same..
Old Oct 23, 2022 | 02:02 PM
hotchicken's Avatar
hotchicken
RE the Eventuri? Party pooper! I’ll admit I did it largely for the carbon scoop. It was a splurge. Did plastic under the hood though.
Old Oct 24, 2022 | 08:22 AM
fridayxiii's Avatar
fridayxiii
@hotchicken Congrats; drive 'er in good health! You have some great driving roads in TN, from Beersheba Springs & many routes east towards NC. Love it up there.
I second the advice about leaving the stance as-is. I lowered my R53 moderately & ended up with some expensive issues. I left my 2019 JCW stock ride height & have no regrets.
Old Oct 24, 2022 | 01:51 PM
TheGeekGuy's Avatar
TheGeekGuy
I had the JCW Coilovers on my 2016 JCW and the JCW exhaust. Since they are MINI parts they are warrantied and don't break the car's warranty either.
Old Oct 24, 2022 | 01:55 PM
hotchicken's Avatar
hotchicken
The problem is confirming fitment for 2022 and forward. Frustrating.
Old Oct 24, 2022 | 03:35 PM
TheGeekGuy's Avatar
TheGeekGuy
If your MINI service or parts department cannot confirm compatibility one way or the other then you need new ones.
The LCI2 is a cosmetic change only, so the mount points , et al should be the same.
Old Oct 24, 2022 | 04:23 PM
hotchicken's Avatar
hotchicken
Factory info on JCW coilovers apparently only goes to 2020.
I get it but am not near another dealer. The local indie BMW/MINI shop doesn’t know anything else. Problem is there are just not a ton of 2022+ in circulation.
Old Oct 25, 2022 | 07:48 AM
dpcompt's Avatar
dpcompt
Check out "The Miniac" on YouTube. He has lowered his '22 JCW Hardtop.
Old Oct 25, 2022 | 10:28 AM
hotchicken's Avatar
hotchicken
thanks! I have seen him on Instagram. I’ll check it out.
Old Oct 26, 2022 | 08:09 AM
MikeMJCW's Avatar
MikeMJCW
Originally Posted by fridayxiii
@hotchicken I second the advice about leaving the stance as-is. I lowered my R53 moderately & ended up with some expensive issues. I left my 2019 JCW stock ride height & have no regrets.
Both above comments are spot on:
I have the JCW Pro coilovers as they lowered the least amount at the time of purchase, 10 or so mm. Car's settled a bit since install 4 years ago,
You can't go wrong leaving it as is tho. Your wheel gap doesn't look bad, might even settle a bit,
Congrad's on the new ride. Nice wheels and that 2022 rear diffuser looks fantastic .
Old Apr 22, 2024 | 09:38 PM
Zackattack28's Avatar
Zackattack28
If you hadn't figured it out, lowering springs will work with the DDC and the new DDC is mechanical so you can swap them out for coilovers without a delete kit.
Antoine524
Apr 10, 2013 06:07 AM
mywifeisgoingtokillme!
Feb 26, 2013 10:37 AM
zimm18
R58 :: Coupé Talk (2012+)
12
Nov 4, 2011 01:36 PM
Mini Me GB
Factory JCW Talk (2009+)
38
Mar 5, 2010 04:16 PM
S1monLM
Aug 1, 2005 05:38 PM
