R50/53 P1447 and fuel tank breather line
Old May 26, 2022 | 08:53 PM
ladsjohn's Avatar
ladsjohn
I've ordered a new fuel tank breather line as mine has broken at the elbow where the small vacuum line attaches. I'm pretty sure it's the cause of the P1447 I recently got.
One end of the breather line attaches to the top of the breather valve (mounted next to the passenger side s/c horn). I'm trying to figure out where the other end attaches. It's routed under the IC but then disappears out of sight.
At first I though it connected to the FPR on the fuel line but from looking at RealOEM, it seems the FPR connects directly into the intake manifold with a different hose.
The line I'm talking about is labelled (4) in this diagram
https://www.realoem.com/bmw/enUS/sho...diagId=13_0977
Old May 27, 2022 | 02:36 PM
ladsjohn's Avatar
ladsjohn
Found it in another thread. It appears to connect directly to the throttle body. Thanks for playing along at home .
Old May 29, 2022 | 03:15 AM
AcidK1's Avatar
AcidK1
Should be throttle body yes. Is there a way you could wrap it in self amalgamating tape or electrical tape to see if the code goes?
Old May 30, 2022 | 03:18 PM
ladsjohn's Avatar
ladsjohn
The elbow is supposed to connect to a vacuum so not sure if plugging it is the right thing to do. No drivability issues with it so I'll just replace it once the part comes in. Hoping I can route it without having to take too much apart
Old May 30, 2022 | 09:45 PM
AcidK1's Avatar
AcidK1
Sorry, I didn't mean plug it, but wrap it so it will still pull a vacuum till the new part arrives
Old May 31, 2022 | 06:47 AM
ladsjohn's Avatar
ladsjohn
ahh, sorry. My misunderstanding. That’s a good idea. Will see if I can do it. Thanks!
Old Sep 3, 2022 | 07:29 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Anyone please correct me if I'm wrong
EDIT: Please forgive the wording in the diagram I posted. I should've meant to write "hose" -not pipe.
bdubya
May 5, 2021 03:55 PM
durantson
Mar 22, 2020 04:39 PM
vanhick
Aug 19, 2015 09:03 AM
dandennis123
May 17, 2013 08:01 AM
SumWon
Aug 2, 2008 10:36 AM
