R50/53 Chime on with no key in
Old May 25, 2022 | 01:48 PM
2out2sea's Avatar
2out2sea
I'm about to throw in the towel on this. I have swapped the starter, put in a new ignition switch and checked all of the fuses. I can't get anything when I try to start the motor. Accessory position lights up the dash, fuel pump primes and dsc module cycles (clicks). But nothing when you turn the key to start.
I noticed something that seems weird too. The ignition chimes even when the key is removed. No lights are on and key is out of the ignition. But when you open the door it chimes as if reminding you that the key was left in. This made me think my problem might have been the ignition switch, but new switch just installed is doing the same thing.
Shrevemini was helping me diagnose things with inpa, but didn't see anything. He ran into trouble trying to get ista to communicate with my car. I've been doa for 2 months. Can anyone help?
Brad
Old May 25, 2022 | 06:41 PM
2out2sea's Avatar
2out2sea
I guess my question got lost in my explanation. Should the chime stop when you remove the key? Thanks.
Old May 26, 2022 | 03:34 AM
Monkey Juice's Avatar
Monkey Juice
Well...
Yes, the chime should stop when the key is removed (unless the headlamps are still on..I think).
My 2005 R53 has had this same issue happen perhaps twice every year since the warranty expired in 2008. I simply reinsert the key, then remove the key. All is quiet.
Best,
Monkey Juice.
Old May 26, 2022 | 06:58 AM
2out2sea's Avatar
2out2sea
Thanks for verifying that... Anyone have an idea why it's doing this?
Old May 26, 2022 | 11:29 AM
RB-MINI's Avatar
RB-MINI
Has the BCM in the passenger kick panel been checked for water damage?
Old May 26, 2022 | 02:13 PM
2out2sea's Avatar
2out2sea
I have not checked the bcm. Other than corrosion, how do you determine if it's tanking?
TheDude
Nov 4, 2021 08:02 PM
Fatandre
Electrical
Jan 29, 2017 09:42 AM
Chiro444
Sep 22, 2015 02:31 PM
jflood1274
Feb 25, 2015 09:05 AM
2003minicooper
Sep 30, 2014 10:40 AM
