Cant tell form the photos - but does that plug have 2 pins in it or 3? If 3, it is likely the connector for the MAP sensor on the intake manifold. The starter cable attaches via 2 small bolts to the side of the head support bracket (timing end of engine). Check realoem.com for images if needed. I find it super helpful!
it’s a two pin. The black 2 pin attached to the intake. I’ll have to find out specifically what the head support bracket is to make sure
