Can I fit 18x8.0 ET35 on F56 Base 2 doors non S ?
Old Apr 30, 2022 | 09:06 PM
Dan F56's Avatar
Dan F56
Hi, I'm new on this forum and I have just buy a Mini Cooper F56 Base non S 2015.
I want so replace my 16in wheels for a 18in wheels.
I have see a lot of nice wheels whit this spec. 18x8.0 +35 offset 66.5CB
I want to add: 215/40r18 tires set.
I have just buy a H&R lowering kit 1.1in (front and back).
Someone have experience this size of wheels and tires with H&R on Mini Gen3
Does I need spacers (front or back)?
It is rubbing or scrubbing?
Thank you in advance!
Old May 1, 2022 | 04:29 AM
Mini-Titan's Avatar
Mini-Titan
Although I cannot give you the answer you are looking for, you CERTAINLY don't need spacers. The lower the Offset, the further out your wheels are from the hub. Spacers are usually required if the shape of the inner part of the wheel (spokes) doesn't clear the brake calipers. This site can be useful in helping you determine how your changes affect the clearance as well as scrub radius and odometer accuracy. https://www.wheel-size.com/calc/
Old May 1, 2022 | 04:58 AM
Dan F56's Avatar
Dan F56
Ok I will not add spacers on my wheels. Can you told me Mini-Titan if this wheels should fit with my spec?
Old May 1, 2022 | 06:11 AM
cmt52663's Avatar
cmt52663
Only if you like to rub the tires on the outer edge of the rear wheel wells.
I'd suggest +43 instead. I am running +45 on 17x8 with 225 Falken Azeni 660 and it's tight near the front struts, but clears - rear is fine.
Cheers,
Charlie
Old May 1, 2022 | 09:49 AM
Mini-Titan's Avatar
Mini-Titan
So glad Charlie popped in to help. He's an expert, I'm not!
Old May 2, 2022 | 06:59 PM
Dan F56's Avatar
Dan F56
I have just order my wheels and tires.
I have choose Niche Vosso 18x8 CB66.5 ET +42 in satin black
And General Tires G-MAX RS 215/40R18
I hope all will fit on my Mini.
Old May 3, 2022 | 03:36 AM
Mini-Titan's Avatar
Mini-Titan
Make sure you use the correctly-shaped Lug bolts for those wheels. It should say whether it uses Conical or a different shaped head such as a ball seat. They look nice!
Old May 3, 2022 | 03:53 AM
cmt52663's Avatar
cmt52663
Fit one wheel only, lugs finger tight, and check all clearances - move the wheel to each corner to be sure.
Hopefully the seller has a return policy if there are fitment problems.
Fingers crossed!
Cheers,
Charlie
Darbys2019MiniJCW
May 4, 2021 03:31 PM
minpoe
Feb 24, 2017 06:16 PM
Snozzberry
Dec 20, 2016 11:03 AM
carfixer100
Jul 23, 2015 09:44 AM
