R56 crank no start
Old Apr 25, 2022 | 10:06 AM
Shields Racing's Avatar
Shields Racing
R56 crank no start
2011 Mini S
98,000 miles
Previous owner stated that car started to surge on highway and became hard to start. Eventually would only crank, no start.
Replaced the high pressure fuel pump, did not resolve the issue.
Tested HPFP relay, its good.
Tested the in tank fuel pump, it works as it should.
Have lots of spark at each cylinder.
Replaced the crank shaft position sensor, no effect.
Checked the 15A fuse for the JBE and its fine.
No codes present, shows engine light while cranking. Tried to scan while cranking but didn't get anything. Battery is fully charged.
Will crank all day but will not fire. Any ideas would be greatly appreciated.
Old Apr 27, 2022 | 07:12 PM
Shields Racing
Solved: did a compression test.
Cyl 1- 3psi
Cyl 2- 40psi
Cyl 3- 60psi
Cyl 4- 30 psi
Motor's shot
Old Apr 28, 2022 | 03:03 PM
Briscoec's Avatar
Briscoec
Might be cylinder head. The exhaust/intake valves are known for bad seals, which allows oil leak by and coke build up where they seat
Old Apr 28, 2022 | 03:23 PM
Briscoec's Avatar
Briscoec
furnitureman9
Factory JCW Talk (2009+)
Jan 23, 2022 02:37 PM
Brian715
Jan 31, 2021 03:18 PM
Minimsippi
Aug 17, 2020 03:16 PM
Strange
Feb 22, 2020 04:44 PM
