Flywheel misalignment after rebuild
Old Apr 17, 2022 | 02:22 PM
gimmea250swb's Avatar
gimmea250swb
I tried to replace the flywheel before engine install after complete rebuild and the wheel didn’t align with the locking pin. I know I rotated the engine after installing the chain which suggests I unlocked the cams to do that. I don’t recall re-locking the cams after I rotated it. Grrrrrr
You can see how far I’m off in the photo. Red dot is where the locking pin is. It seems to be just enough to be one link in the chain if I’m misaligned. What would you do?
Im thinking I’ll pull the valve cover to see how the cams are situated. Any other thoughts?
Old Apr 18, 2022 | 01:53 PM
oldbrokenwind's Avatar
oldbrokenwind
If crank is rotated more than 90 deg with cams installed but not locked, you better look for bent valves.
Old Apr 18, 2022 | 05:28 PM
gimmea250swb
Okay, phew. I pulled the valve cover and put the cam locks on and they weren't clocked properly. I rotated the crank about 5* or so to align them and the flywheel locking pin falls into place. I avoided a big one there!!
mike_miniman
Apr 1, 2022 12:46 PM
gimmea250swb
Mar 19, 2022 07:12 PM
danraabe
Oct 21, 2019 02:50 PM
Parker Young
Jun 16, 2019 11:57 AM
afadeev
Jun 21, 2015 05:31 PM
