no compression in cylinders 1 and 4
after a long road trip with cruise control at 80mph, suddenly cel started blinking when i was climbing a small hill. i immediately stopped the car, popped the hood open, everything seemed ok so i restarted it, it was chugging like crazy, but it worked. obd reader and bimmerlink states misfire in cylinder 4. nothing else.
here comes the stupid part, i kept driving till i get home (about hundred miles), thinking it's just a dirty injector or coil or plug. car seemed fine over 3k rpm so i lowered a gear and cruised around that rpm range.
next day, i removed plugs, 4 was just straight up black, others looked ok. i dunno what i was thinking but i swapped plugs and coils, tried to start to car, it started and died immediately.
i called a tow and bring the car to a reputable independent service, they tried starting it, it started again just to die immediately. they removed plugs and now there are 2 plugs extremely black, one is from the 3rd (which i swapped with 4th the day before) and one is from the first, which was at mint condition before i tried starting it!!!
compression test came next: no compression at all in 1 and 4. wtf? while 2 and 3 pushing 160psi.
i have a very bad feeling about this guys. i'll keep you guys posted.
first update: upon removing the head, valves in 1 and 4 is bent. cylinders and walls look good, new set of valves seems like is all i need. it seems like the timing job my other guy did 10k miles prior was bad (my long term fuel trim was around -10 percent after the timing job indicating rich condition, i thought it was just a bad injector or something like that), after a power surge, timing skipped a tooth or two and valves contacted pistons. at least that's what they are telling me. i'll keep you guys posted for future references.
Ronald Wright
Oct 12, 2021 04:51 PM
Bishopthomas
Mar 23, 2012 06:01 AM
