Misfires P0301 and P0302
Old Mar 30, 2022 | 08:40 PM
Countryman2012's Avatar
Countryman2012
Hello guys, my R60 had a code of P0301 and P0302. We replaced sparkplugs and replaced head gasket cover. Still had the same code. Switched around the coil packs but still have same code and engine light re appeared after a minute after I fired up the engine. So our next step is to check and replace, if needed, injectors. Not unless you guys have idea what should I do first. For me as a low level home-guy mechanic injectors will be a next high level.
Old Apr 10, 2022 | 03:16 PM
Vanski's Avatar
Vanski
Was the engine light "FLASHING"?
Old Apr 10, 2022 | 07:45 PM
Countryman2012
Yeah. I end up having it rebuild it. 0 compression on no. 1. Tell you the truth I don’t know what happen.
Old Apr 11, 2022 | 04:49 AM
Vanski's Avatar
Vanski
Hi @Countryman2012
I feel and share your pain when I had to do the head job. My immediate guess is the previous owner who was a teenager redlined the engine several times and put 87 octane(regular) which you’re not supposed to.
check out the photos on what I’ve done 3yrs ago just to gain access to the head(NOT FUN). Ever since I’m putting in mid grade gas(89 octane), it is running beautifully ever since and still now.
Old Apr 11, 2022 | 04:01 PM
A383Wing's Avatar
A383Wing
after you switched coils & plugs.....did you clear the codes before you restarted the engine?
Bryan
Old Apr 14, 2022 | 11:40 AM
Countryman2012
Originally Posted by Vanski
Hi @Countryman2012
Just got an update from the shop…they are saying that the piston rings might be the problem now. They did a leakdown test thats why they think it is the rings. 😩
Old Apr 14, 2022 | 04:06 PM
Vanski's Avatar
Vanski
@Countryman2012
Oh my and shocked 'cuz piston rings rarely ever go. I never heard that rings go bad that soon. How many miles did you say your car has? Mine was 102K miles when the exhaust valve chipped away and broke. Knock on wood my valves are humming away at a current mileage of 132K
Old Apr 14, 2022 | 08:54 PM
Countryman2012
She is on her 108k miles. I’m lost too what could’ve been the reason. Looking for an engine now and will work on it maybe next week depending on the space in my friend’s shop.
Old Jul 17, 2022 | 06:13 PM
eddiemac's Avatar
eddiemac
P0302
What does it means when the check engine light is flashing?
Old Jul 17, 2022 | 06:41 PM
CR&PW&JB's Avatar
CR&PW&JB
Urgent engine issue that needs to be checked out ASAP.
Of course, could be a computer error but you do need to have it looked at pronto.
Old Jul 19, 2022 | 08:19 PM
A383Wing's Avatar
A383Wing
Means don't drive it until you have it checked out...normally means serious misfire and possible cat meltdown....plus other damage
Bryan
Burnt Rubber Productions
May 24, 2022 01:46 PM
wojtek@pagacz.ca
Jun 9, 2019 09:22 AM
shade tree mechanic
Nov 14, 2017 07:10 AM
valvashon
Jun 12, 2013 01:54 PM
tmack45
Aug 21, 2009 05:12 PM
