2013 CMS All4 Periodically Struggling Uphill
Old Mar 28, 2022 | 09:04 AM
Kai Bell's Avatar
Kai Bell
Hello,
So this has been an intermittent problem on my car for a while now, during summer when it gets really hot here in So Cal, my 2013 CMS All4 (93,000 miles) will struggle occasionally going up a grade for extended periods of time, no jerking, no stumbling, just a sudden loss of power and acceleration. It will kind of hold it's speed and very gradually start to go slower, almost like there is a boost leak and it stopped making pressure. No warning light of any kind. However I have monitored boost with a bluetooth OBD module in the past trying to catch it, and the couple times I have it does not show a loss in boost pressure. Checked the intake tract for leaks, charge piping, nothing.
The only code that has been thrown on this car is a P0171 (system lean bank 1), I have checked for vacuum leaks and found nothing unless it is potentially the PCV in the valve cover. Leads me to think it is a fueling issue but it seems inconsistent with a lot of the failing HPFP symptoms but I could definitely be wrong there. The price of that part makes me wince and I don't want to throw it at the car and have that not be the case.
It seems to only happen when it's 90+ degrees F outside, and I have had a temp warning on one occasion, but it promptly went away and I have never seen it again.
Could this be related to my cooling system? I would think it would throw a code if the thermostat was stuck open. HPFP? Ignition Coils? PCV/valve cover?
This has not happened in over 4 months and never happens under normal driving, but we had a hot day here and was going up a large freeway grade and it came back to remind me it was still there.
Any help is appreciated. Thank you.
Old Jun 24, 2022 | 01:10 AM
SunBird's Avatar
SunBird
Have you found out what this is? Mine was having sudden drops in power... it was a crack on the intake at the turbo. I patched that and the car ran so much better over all. It just started doing the lose power, kinda drop thing again now that its been over 85+ degrees F... have to check my patch on the intake.
AW135751
Jun 11, 2020 06:00 AM
AW135751
Jun 11, 2019 12:56 PM
pocketmaster
May 17, 2019 09:01 AM
one73ronin
Aug 17, 2017 11:05 AM
MNIPWR
Jun 11, 2015 05:45 AM
