Lacking Boost (2B5C-DME)
Old Mar 21, 2022 | 05:59 PM
q-uest's Avatar
q-uest
R56 N14 JCW
Currently fighting 2B5C-DME and losing...
I've looked through a lot of the threads on here but coming up short on a lot of the fixes people had
As of this moment I am pushing about 2-2.5 psi max, read via ultragauge, when attempted to push the car harder it will throw a CEL.
For diagnostics, I have done a smoke test and pressure test and unable to find anything concrete.
Replacements include:
MAF sensor replaced
Throttle body cleaning and replaced
Boost solenoid replaced
Cut off/diverter valve spring replacement to whole sensor replaced
Walnut blasted ~10k ago, just put a can of CRC turbo/intake cleaner through
Catch can installed, valve cover to manifold
Nothing above has worked and seeking wisdom
Old Oct 24, 2024 | 10:12 AM
trinitony's Avatar
trinitony
Hi, did you ever determine what was causing you the issue?
Old Oct 24, 2024 | 06:57 PM
q-uest's Avatar
q-uest
if I remember correctly.. it was the vacuum line to the turbo, reseated and worked
Old Oct 27, 2024 | 09:37 PM
trinitony's Avatar
trinitony
Thanks.
Even with smoke testing, it didn't show up initially?
AW135751
Jun 11, 2020 06:00 AM
AW135751
Jun 11, 2019 12:56 PM
sharmadaven
Jan 4, 2017 03:20 PM
scottab36
Aug 18, 2012 09:03 AM
blownmini
Mar 23, 2003 06:15 PM
