R56 Coolant System Help Request...
Old Mar 19, 2022 | 06:41 PM
robncar's Avatar
robncar
I broke a coolant tee fitting while doing an oil change. While replacing the hose, I noticed the elbow does not have an electrical connection (sure can't find it in the harness) but appears to be a coolant temp sensor? Is this normal to not connect it? I've seen posts where they replaced it with an elbow that has a bleeder screw and some that used a different hose (deleted the elbow)... what is best practice? 2012 S with an automatic. I started this job a couple months ago and contracted COVID, just starting the repair now and forgot what I did during disassembly. The picture is not my car but very similar. Also, the car is now 10 years old, would this be a good time to replace the coolant hoses with silicone since I'm in there? Is there a preferred kit? Thanks!
Old Mar 20, 2022 | 09:36 AM
Gubi's Avatar
Gubi
That sensor is a retrofit. What happened is the original temp sensor in the thermostat would fail, so when it did they replaced it with an inline one.
Later on I believe there was a recall to replace the thermostat, again due to temperature sensor corrosion. The new thermostat has a working sensor, so when the thermostat was replaced they used that one and then just abandoned the inline one in-place.
You can just leave it. The only problem is sometimes they start to leak at that sensor, in which case you have two options: either glue it in place with some silicone, or replace that upper hose with a one-piece one that doesn't have the sensor.
Old Mar 21, 2022 | 05:03 AM
robncar's Avatar
robncar
Thanks! I had the entire job complete and couldn't find the connector to that sensor! Took everything apart again to search. Nope. Put it back together and it ran fine, no issues. By the way, was 2012 a mid-year change over? My 2012 seems to not match diagrams and the service manual here and there... yay me!
Old Mar 21, 2022 | 08:10 PM
Gubi's Avatar
Gubi
2012 was the first year of the N18 engine, yes. So there are differences from the earlier cars.
If you go to realoem.com and enter your build month you can find parts diagrams.
Old Mar 22, 2022 | 03:09 AM
robncar's Avatar
robncar
Thanks! I found this at that site with the last seven of the VIN:
Series: Mini R56 LCI
Body: 3 Doors
Model: Cooper S
Market: USA
Prod Month: 09/2011
Engine: N18
Type Code: SV33
Old Mar 22, 2022 | 03:12 AM
robncar's Avatar
robncar
So... this now being a 10 year-old vehicle, replace coolant hoses with silicone?
Water pump, rear coolant pipe? Etc.? What is best practice?
Old Mar 24, 2022 | 10:45 AM
https://www.northamericanmotoring.co...ntryman-s.html
So to buy pass the system once you updated the thermostat housing and updated the pigtail
https://www.realoem.com/bmw/enUS/sho...diagId=17_0393 Parts in this link, copy and paste them into our site search.
As you can see with your MINI, since the wire is disconnected, you can upgrade the hose and get rid of the old part #1 for the manual transmission.
https://www.ecstuning.com/Search/Sit...h/17122754221/
#3 if you have an automatic transmission
https://www.ecstuning.com/Search/Sit...h/17122754222/
BernieCoop
Jul 30, 2015 04:02 PM
imagineary
May 16, 2014 12:54 PM
gknorr
Oct 6, 2012 07:52 AM
Old chuck
Mar 9, 2012 04:43 AM
kapps
Jun 20, 2007 03:22 PM
