I need some help for decisions to remove weight from my 2019 Mini JCW for AutoX. I have pulled out the rear seat and rear siding already...got the vehicle down to 2720#s.
Need Ideas for Other Weight Removal Ideas. I really want to get down to 2300# or so...
- Replace window glass with plexiglass
- Remove doors
- Remove gas struts from hatch
- Remove bumper aprons
- Crash diet for driver
- Sand body panels down to bare metal
- Helium in tires
Those are some ideas. You didn't say they had to be good ideas
I have seen a couple people on here that bought a smaller battery to save a few pounds, but I don't know those details.
Buy lighter wheels and tires. Check out Eneki RPF1 vs. stock wheel weight. Also get the lightest tires you can find. Unsprung weight is a performance and handling killer . Race teams send thousand$ to shave that weight off. You can drop nearly 40 lbs with new wheels and tires and in the process gain approx 10 WHP and wheel TQ.
I reckon your list is good Darby. I assume you've done battery, right?
I've good wheels/tires, and am running a base model of the same car, and I was at 2,770 when last corner weighted (no ballast).
I bet you can get 20# out of the seats, the rears aren't as heavy but could be deleted if you have not done so.
But I assume that you understand that our chassis, lovely as it is, will not be top rank nationally against 320hp 2,200 pound Hondas and their ilk. I have watched SMF up here in the NER for quite a while, and my example is a car called "Smurf"...
I shall be quite interested in what your final weight becomes.
Cheers,
Charie
I am at 2720#s right now after removing the Inside Back Seat Area...but I need more weight GONE!!!
I am also looking for a Hybrid Turbo for more power...
Just ordered two racing seats that weight 22 pounds each,,,the stock seat with sliders underneath weight 44.6 pounds so I figure I will save 40 pounds...gotta get everything I can...shpould get me down to under 2700 pounds,,,basically 2680 from 2720
Well I found some Mucht Schnell Competition Lightweight Floor Mounts for Racing Seats that will fit a F56 Mini. Now when they get here...they will ship tomorrow...I will be able to install the Race Seats safely. All together I will save approximately 44 pounds
on my Mini which should get me down to 2676!!! Got some more ideas to try to get down to about 2600...
Basically I spent $1050 for 2 Race Seats and two sets of Floor Mounts...I'm Happy if all works out
Do you have airconditioning still onboard ?, there you find 20 kgs. - hood/ makrolon boot lid ea.12 kgs, ..... 12 kgs exhaust. Latest our 3,5 kgs seats as extra for "The few" which can be chosen to replace the already 11 kgs lighter Recaro of the base model.
Got my mounting plates from Macht Schnell today...looks like they will work perfectly...looks like the two seats will save 44 pounds after mounting! The Mini should weight in at 2676 compared to when I bout it at 2875 so 199 pnds out of the Mini so far...
Well I got both seats installed with minor adjustments to the Macht Schnell Mounts. I did have to drill One Hole and Thread The Hole near the back of the mounting aluminum and it worked!!!
Going to AutoX this weekend. My Mini still weights 700 pounds MORE than the other SMF cars but I do scare them. The top five in our Tire SMF Class finish within 1 second of each other and I am in that mix.
Next I really want to Lexan my windows to save more weight...Later I will try to get more horsepower with some kind of Turbo Upgrade
You will never fo back once you're strapped in a harness!!
I have raced cars since I was 20 at AutoX and Road Raced for years including 6, 12 & 24 hour races with Mazda including the first Spec Miata until 1/01/2000. I quit after that to do Triathlons. I am now 65 years old and racing AutoX Now AGAIN!!!
I have used 4 and 5 point racing harnesses for years...don't need one in the Mini JCW right now,,,lol
