Suspension Front strut install need help
Old Mar 2, 2022 | 05:41 PM
r53racer's Avatar
r53racer
Hi Nam,
I'm installing Swift springs, Bilstein B6, and IE Camber plates. I've done this job twice on another R53. This one is giving me a hard time. With the IE Camber plates on, the lower part of the strut wont get into the knuckle. No problems with the OEM strut mount. It seems like the extra thickness of the IE plate extends the strut down preventing the knuckle to go under the strut, just by half and inch or so. I disconnected steering tie rod, I tried loosening the axle nut for more play, it didn't help, I tried zip tying the spring to compress it, but I still cant' push it up to make it over the knuckle. Any advice?
BTW, this is on the passenger side. I haven't tried doing the driver side.
thanks,
Old Mar 2, 2022 | 05:59 PM
MCS4FUN's Avatar
MCS4FUN
I had similar R&R issues with combo Helix plates plus Koni Yellows. My own method involved dropping fully within max excursion, then manually rotating steering to optimal clearance angle before "persuading" alignment back into the knuckle. Used small floorjack to help facilitate once best engagement angle achieved.
Old Mar 2, 2022 | 07:19 PM
r53racer's Avatar
r53racer
When dropping fully, did you push the control arm down or step on it?
Old Mar 3, 2022 | 09:48 AM
r53racer's Avatar
r53racer
Update. I was able to get it in using a piece of 2x4 and a floor jack. I jacked up the collar just enough to get the bottom over the knuckle. Worked like a charm, took 2 minutes.
Old Mar 3, 2022 | 08:59 PM
bump32's Avatar
bump32
Good idea. I had a tough time also with the passenger side when I added the fixed camber plates. Don’t remember the drivers side being as hard. 🧐
i also would like to hear your feedback/review on the swift springs? Track vs street? And how much, if any, lower the car is?
Old Mar 4, 2022 | 09:50 AM
r53racer's Avatar
r53racer
I love the swift springs for both track and street. I think swift is the best for dual duty. I have not tried any others though.
See more of my response here
https://www.northamericanmotoring.co...ml#post4572992
P4pumpman
Jun 24, 2014 03:00 PM
el chupacabra
GP Talk (2006)
Apr 10, 2012 04:43 PM
tpark
Suspension
May 7, 2010 11:28 AM
mach schnell
Suspension
Jan 20, 2009 03:15 PM
2Cool
Suspension
Mar 8, 2004 09:24 AM
