R56 Confused... no dipstick AND no "check Engine Oil level" option in CID
Old Feb 26, 2022 | 01:23 PM
Bohead's Avatar
Bohead
Just got a used 2015 F56. Love the drive and its a super fun car to boot around in. Now I've been reading about the dipstick challenge HAHA, but I'm kinda in a stuck spot... My center radio doesn't have the "Check Engine Oil Level" option in the vehicle information section. HUH??? Is this something that needs to be enabled? Shouldn't it come enabled regardless what trim level I have? I have a 2015 Cooper @ Hatch with the JCW appearance stuff, but most of the interior is pretty basic.
HELP!!
Old Feb 26, 2022 | 02:25 PM
RichsMINI's Avatar
RichsMINI
Hi Bohead,
Congrats on the MINI!
This is not an option that needs to be enabled and it cannot be hidden. It’s standard on all trims because there’s no dipstick
Here are the videos on how to check oil with the basic radio (MINI Radio 2.0) and MINI Connected + Visual Boost
: MINI Radio 2.0 :
https://m.youtube.com/watch?v=Gb8Ex_Kpikg&t=0s
: MINI Connected + Visual Boost :
https://m.youtube.com/watch?v=NtxVFi_0Vx4
If you still don’t see the option it may be best to reach out to your local MINI Service Department.
Have a great weekend and hopefully this helps,
Rich
Old Feb 26, 2022 | 04:41 PM
Bohead's Avatar
Bohead
Thanks @RichsMINI !
Yea I figured that is should just "be there" as it would be a neccessary feature. I am positive that the option isn't there, and I've followed the same video but the option just isn't there. when I select "Vehicle Status" I only have "Service Requirements" and "Check Control" as options. Completely different options from the video you shared. Pic below as proof!!
Just don't get it! LOL and the "TEL" button doesn't work (I don't even have bluetooth in the settings section to set up a phone... WTF?)
Old Feb 26, 2022 | 04:48 PM
Bohead's Avatar
Bohead
Is there an older Gen mini that maybe this radio was swapped in from? An older gen that has a dipstick? Thinking maybe the previous owner put it in to replace an infotainment unit he had and cheaped out on the replacement just to trade it in at the dealership?? Possible?
Old Feb 26, 2022 | 05:53 PM
Jason Cornelius's Avatar
Jason Cornelius
Maybe this…
To check your oil, from the main menu of your radio (Connected, XL, or base - it's the same), go to VEHICLE INFO, then to VEHICLE STATUS. There is an option to measure engine oil level. The engine has to be warmed up and you have to be parked, the measurement takes a minute, but your screen will display a gauge that will show how much oil you have.
Old Feb 26, 2022 | 05:54 PM
Jason Cornelius
https://www.minif56.com/threads/dip-stick.44953/
Old Feb 26, 2022 | 07:43 PM
Bohead's Avatar
Bohead
Hey @Jason Cornelius if you read my original post and check out my pic in the thread, you'll see I've tried that and the "Vehicle Status" menu doesn't even have that as an option to select. That's why I'm stumped.
Old Feb 27, 2022 | 03:52 AM
RichsMINI's Avatar
RichsMINI
No, the radio wouldn’t be from a previous generation MINI because it was introduced/released for the third generation MINI (which your model is) and is not compatible with earlier generations.
It’s always possible the previous owner/dealership had the radio replaced and it was never coded/programmed (some parts need to be coded after they are replaced to fully function).
I don’t know if the radio can be downgraded.
- I would contact the dealership you purchased it from and asked if they replaced it. If it’s not an official MINI dealership maybe they didn’t know it needed to be coded/programmed.
It’s always possible this is the original radio and it’s having some kind of hardware failure and needs to be replaced.
- In both scenarios it may explain why the radio doesn’t have the option to check engine oil or have Bluetooth functionality.
I hope this problem gets resolved quickly
Rich
Old Feb 27, 2022 | 05:55 AM
30 ounce's Avatar
30 ounce
Engine has to be running and warmed up before it will give you the option to check oil.
Old Feb 27, 2022 | 06:21 AM
Bohead's Avatar
Bohead
Its not there even after a 2 hour drive home after picking it up from a dealership... all the videos I've seen the option is there, but greyed out... for my radio, the option isn't even there to begin with :(
Old Feb 27, 2022 | 06:26 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Seriously, I would call the dealer first thing Monday morning and explain it to them.
Old Feb 27, 2022 | 06:43 AM
Bohead's Avatar
Bohead
Yea, I'm thinking that's really my only option. Closest Mini dealer is 1 hour away so I was trying to see if there was something I could do at home prior to visiting. Forums have saved me several times for my other vehicles so I figured I'd give it a shot :D
Old Feb 27, 2022 | 10:39 AM
TVPostSound's Avatar
TVPostSound
Uh, NO!
It will show the check oil menu, but won't activate until hot.
Old Feb 27, 2022 | 11:03 AM
30 ounce's Avatar
30 ounce
Uh, yes! It will show the oil menu but the option to check level is grayed out until warmed up.
Old Feb 27, 2022 | 12:35 PM
TVPostSound
Thats how you should d have worded it first!!
genik
Mar 3, 2017 02:29 PM
im112233
R55 :: Clubman Talk (2008+)
Mar 24, 2016 07:21 PM
DAVIDLEERAD
Apr 22, 2015 06:21 AM
Bhavin Userofreality
Oct 27, 2013 07:23 AM
byron h
May 5, 2013 07:33 AM
