R55 lower brake lights
Old Jan 29, 2022 | 05:12 PM
Avaughner's Avatar
Avaughner
lower brake lights
the lower rear brake light on our 2016 Clubman burnt out. Got a new one from the dealer part No. 63 11 7 359 245 after installing light still doesn't work. I called the dealer they said you can't replace the bulb you have to replace the entire fixture, that seems crazy to me. Also now the left turn signal is blinking very fast the dealer said that was because of the lower fixture needs replacing.
I took the inside bulb (not sure what is for since I can seem to get it to illuminate) and moved it to outside and brake light now works but still have fast blinking turn signal on same side as the problem lower brake light. I put the new bulb I got from the dealer in the inside socket.
Does anyone have any insight on this situation?
Old Jan 30, 2022 | 05:28 AM
jwzimm's Avatar
jwzimm
You are in the wrong forum I'm afraid. This forum is for 2nd generation Mini Clubman's (R55). Yours is an F54. The correct forum would be here: https://www.northamericanmotoring.co...talk-2015-442/
Old Jan 30, 2022 | 06:56 AM
Avaughner's Avatar
Avaughner
Old Feb 3, 2022 | 11:39 AM
https://www.northamericanmotoring.co...a-failure.html
Some info here ^^
cjv2
Sep 17, 2023 04:10 PM
Foxtrot3000
R55 :: Clubman Talk (2008+)
Mar 24, 2018 12:21 PM
Bad4Fun
Electrical
23
Dec 1, 2011 01:05 PM
DeanoTX
Dec 8, 2009 11:15 PM
m3ster
Sep 28, 2003 06:32 PM
