R57 Replace key slot
Old Jan 7, 2022 | 07:51 AM
kromerok's Avatar
kromerok
Replace key slot
Anyone know of a video that would show me how to replace the key slot for a 2014 r57?
Old Jan 7, 2022 | 11:14 AM
Dirtiegirtie's Avatar
Dirtiegirtie
I do not.
However, I recently found a video and threads regarding the step-by-step process for removing the entire dashboard for an R57. You might find those a little quicker. I'll see if I can find them as well.
Old Jan 7, 2022 | 12:57 PM
kromerok's Avatar
kromerok
Thank you
Old Jan 7, 2022 | 03:59 PM
Dirtiegirtie
Check out this video to get an idea of what you're in for. The key slot falls out around the 6:15 mark.
Good luck! My only advice is take PLENTY of pictures at you take everything apart.
Old Jan 8, 2022 | 07:00 AM
kromerok's Avatar
kromerok
Thank you again
Old Jan 11, 2022 | 09:43 PM
kromerok's Avatar
kromerok
I was able to get it off and swapped out the key slot but now the key is stuck in new slot. From everything ive read on it it should be plug n play.
i
Old Jan 11, 2022 | 10:31 PM
Dirtiegirtie
Kromerok,
While searching for your issue I stumbled upon this link that shows step-by-step how to replace the key slot. Hopefully I didn't steer you wrong with the previous video.
https://www.pelicanparts.com/techart...eplacement.htm
After the directions you will find comments, and it seems like your issue is not unique. I would suggest posting your issue there.
StuSegal
R55 :: Clubman Talk (2008+)
Aug 18, 2021 08:20 AM
Mrdi
Jan 11, 2015 03:42 PM
chastings68
Aug 2, 2014 12:54 AM
jimmo
Dec 1, 2007 01:09 PM
Electron_Mike
Nov 11, 2005 03:35 AM
