mini Countryman JCW N18 stall while warm start
Old Dec 28, 2021 | 02:12 AM
Mahmoud Soliman's Avatar
Mahmoud Soliman
hello ,
i am having countryman JCW 2014 N18 engine and i am having odd behavior when i start the car when it is warm it start and stall and to make i start i need to push the acceleration paddle a little after that it idle fine with now problems , i don't know what is the problem and it didn't happen while cold start ,no error codes
there is another behavior rarely happen sometimes while driving i don't know if it is the same problem , when i am driving and press the brake to slowdown if i release my leg while the car is shifting down i noticed that the car accelerate automatic for 1 sec and return normal again and when i am pressing brake on traffic light and the gear on D when i release the brake the RPM drop and get up again something like hesitation or that the car will stall but it doesn't stall .
thank for anyone that can help me .
Old Dec 30, 2021 | 02:24 PM
CoolHands's Avatar
CoolHands
Maybe high pressure fuel pump, although apparently it is less common on the n18. You can get them repaired despite what mini tell you, search ebay for repairers.
Old Dec 31, 2021 | 04:51 AM
Mahmoud Soliman
i read the high pressure fuel pump readings and there is nothing wrong with its pressure on the scan tool
Old Dec 31, 2021 | 05:24 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Fuel pump would be a cold start issue, not warm start. My guess would be vanos related, but can’t make a true educated guess without codes…
Old Dec 31, 2021 | 06:25 AM
Mahmoud Soliman
the problem is there is no codes, only o2 sensor and replaced it and now there is no codes but the issue still happening
King King
Jan 4, 2021 02:38 PM
GoneGator66
Oct 27, 2020 08:50 AM
E-ROXSPIN
Sep 27, 2018 06:52 AM
Michael Webb
Dec 4, 2012 07:51 AM
funracer
Mar 11, 2009 02:59 PM
