Best Scan Tool to Diagnose SRS Issue
Old Dec 27, 2021 | 09:59 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Got my SRS warning light. Checked connectors under seat but didn't find anything amiss. Might as well bite the bullet and buy a good scan tool that will identify the culprit AND, more importantly, clear the light. As I understand it, the SRS will only allow three tries and, if not fixd, it will require a new SRS control module so I want to get this right the first time. What's the best scan tool around for my money? Foxwell NT510 Elite or ?
Old Dec 27, 2021 | 03:02 PM
jjcsnlynn's Avatar
jjcsnlynn
Have the Foxwell 510 ad so far it does everything that I want it to do except reset adaptives. I use the manual scan because the VIN scan doesn’t pick up all the modules.
I’ve never hear about the 3 time you need to replace a module.
Old Dec 27, 2021 | 03:11 PM
ssoliman's Avatar
ssoliman
I’m sure the foxwell works well.
inpa is free if you have a windows laptop. Any old laptop will do.
inpa is what bmw uses
Old Dec 27, 2021 | 03:13 PM
deepgrey's Avatar
deepgrey
I'm pretty sure I've cleared airbag codes on my car more than three times. I've only ever used INPA for SRS stuff, so I don't have any suggestions for a scan tool.
Old Dec 31, 2021 | 01:28 PM
NC TRACKRAT
Veteran: Navy
Well, I already had an AUTEL AP200 dongle for our Porsche Macan Turbo so I just purchased the BMW add-on software for $21.95 on Google Play. It identifed a whole bunch of codes in addition to the SRS indicating the Battery Safety Terminal was the problem. After checking the usual suspects like the connectors under the seats, I elected to do the simple thing: Disconnected the battery for a few minutes, pulled up the codes and erased them all. Re-started the car (with my safety belt engaged) and the SRS light went out. Hopefully, it won't come back.
Old Jan 1, 2022 | 08:33 AM
ssoliman's Avatar
ssoliman
The srs related connection at the battery is a common one it seems.
Call scrub or similar iirc
for me cleaning the connector worked
Edit: or scrib?
Old Jan 1, 2022 | 12:40 PM
NC TRACKRAT
Veteran: Navy
After disconnecting the NEG battery terminal, I wiggled the connectors at both ends of the cable from the POS side to the control box. Maybe that was all it took. ???
lajya
May 12, 2017 06:05 AM
MiniCJCW
Mar 9, 2017 10:07 PM
shellysosmelly
Mar 9, 2008 05:49 PM
