code p0107 *changed the map sensor* still not working
Old Dec 22, 2021 | 02:00 PM
paulyyyyb's Avatar
paulyyyyb
hi guys this freaking car is bothering me for four months now but i still cant diagnose it. Car is hesitant on higher speed and rpms. I have an r53 with a p0107 code which tells me its about the map sensor. I changed it with a brand new oem sensor but still wont work. Went to my mechanic and they couldnt diagnose the issue and told me i might need a walnut blasting. I didnt even know r53 doesnt need a walnut blast.
I tried seafoaming it and it worked for 4 days then the issue came back. Limping, hesitating to accelerate, stalling on high rpms. Anyone has ideas on what to do? I love the car but its just a moneypit at this point
Old Dec 22, 2021 | 05:18 PM
ssoliman's Avatar
ssoliman
Likely the t-map sensor. Should be replaced with OE part
Old Dec 28, 2021 | 05:34 AM
Mr_Stop's Avatar
Mr_Stop
Which map sensor did you replace? The one on the front of the engine, or the drivers side? The T-map @ssoliman mentioned is the one on the front of the engine.
I recommend that you download and install ISTA+. It's BMW's diagnostic software. You'll have to search around some BMW forums to find a download. I tried INPA, but found the ISTA+ much more user friendly and has better diagnostics.
You can connect a laptop to your car using a cable like this:
Amazon Amazon
You just need to make sure the switches are in the correct position.
Mr_Stop
Sep 13, 2021 11:38 AM
gatorsr53
Sep 8, 2015 03:30 PM
alexs3d2
Sep 6, 2014 09:59 AM
jaytech
May 27, 2009 09:43 AM
jrprich
Sep 6, 2008 06:46 PM
