Interior/Exterior From Piano Black to Raw Carbon Vinyl Wrap
Old Dec 21, 2021 | 05:45 AM
Minifan07's Avatar
Minifan07
Did this a few months back but hadn't the time to share my results. I looked into getting the actual carbon parts but for the look the expense was not worth it. I honestly prefer the satin-like /raw carbon look over the glossy bits anyway.
I used VVivid vinyls, they actually come in different finishes and colors from matte to full gloss.
Taking the pieces out was obviously the easiest part, like any vinyl-related projects you have to have a lot of patience and let the heat gun do it's thing.
The AC controls was by far the most difficult due to the somewhat concave curves, I ended up going through several versions because it would pop up on a warm day even when using adhesive promoter.
The trick that finally worked for me was pre-heating/shrinking the film prior to application and then liberally using the adhesion promoter and heat gun. Everything was cut by hand, I used matte black strips to clean up the finish around the three turning controls to give it an OEM look.
Old Dec 21, 2021 | 06:12 AM
maccoder's Avatar
maccoder
It does look OEM indeed! Fantastic job!
Old Dec 21, 2021 | 06:23 AM
Minifan07's Avatar
Minifan07
Thanks!
Malcon
Jun 11, 2012 05:19 PM
masterd78
Apr 23, 2011 12:34 PM
Malcon
Jun 5, 2009 10:53 AM
speltzer
12
Sep 18, 2004 04:19 PM
