R56 Limp mode after warm start
Old Dec 10, 2021 | 04:51 AM
obgmugen's Avatar
obgmugen
Been noticing when i cold start, sometimes my idle rpm goes up then dips, goes up, dips....like the engine is trying to compensate for a lack of o2 or fuel. After about 10 seconds it levels off and seems to be fine.
Will drive until it gets to temperature and everything seems to be fine - rpm, etc. I get to my destination and shut off the engine.
This is where i have a problem. After several minutes or even a couple of hours, i would then start up ( the still-warm engine ) and it would seem fine until i'm caught at a long idle. If i am at a long traffic light or stuck in a drive through, it would go limp mode and the engine would run rough. Shut off, remove key fob, restart fixes it. Again, on a cold start and once it gets up to temp, it doesnt matter if i'm stuck at a light or not....it doesnr go limp mode. Only after its been shut off for a while and then reatarted that i get that.
Having said all that, do you guys thing its the:
HPFP
Fuel pump
Clogged intake valves
Injectors
Or something else
Would it even run "normal" if any one of the above is failing?failed?
Old Dec 10, 2021 | 05:14 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Checking your other threads, you have a 2010 Cooper S? My gut says HPFP...
OreoPanda
Aug 4, 2023 10:45 AM
maddog2020
Dec 1, 2019 10:00 AM
starionturbo
Sep 18, 2011 12:16 PM
R53
Jun 1, 2010 02:08 PM
