Cylinder 3 misfire
Old Nov 12, 2021 | 09:38 AM
gimmea250swb's Avatar
gimmea250swb
Cylinder 3 misfire
2011 R56 JCW
I've been having a problem which I thought was related to my HPFP which was rebuilt about a year ago (near stalling on start). I sent the pump in because it was under rebuild warranty and I replaced it. The issue continued and I decided it could be a fuel supply problem and I changed out the fuel filter and in tank pump. The issue persisted and all of a sudden I got a P303 warning (Cylinder 3 misfire) - I did not have a warning to this point. I swapped coils and cylinder 3 was still bad. I pulled the plug and found that the center insulator had dropped so I thought that was the source. I installed a new plug and there's no change. I just pulled it and the plug is wet. Is that because the cylinder isn't firing (maybe unspent fuel)?
The engine (short block) was replaced by a mini dealership 15,000 miles ago.
Any thoughts/suggestions on troubleshooting is appreciated.
Old Nov 12, 2021 | 09:54 AM
gimmea250swb
I posted this under 1st Gen, but should have put it in R56. I've copied the thread there.
shrevemini
Sep 27, 2021 02:55 PM
jctrue
Sep 3, 2021 10:21 PM
Jordan Smythe
Jun 11, 2021 12:32 PM
thevastdifference
Jun 19, 2018 01:15 PM
kazzy1313
Dec 18, 2015 06:02 PM
