R55 Issues with Mini Cooper Clubman S
Old Oct 14, 2021 | 07:23 AM
tracker797's Avatar
tracker797
So I just replaced the water pump & thermostat housing and are getting 3 error codes and random acceleration issues. P1497, P115D, & P15E8
I've cleaned the mass air sensor, but not dice. Any advice would be appreciated.
No mods have been made to my car.
Old Oct 14, 2021 | 11:29 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
What your is the car, which engine?
P1497 is a Downstream of Throttle Air Leak. If you had the intake manifold off, I would suspect something didn't sealed up correctly when reinstalling components.
It is possible that P115D is also related to a manifold leak, since the MAF signal will now be off because of the leak.
The P15E8 code has to do with the coolant temp sensor. Since you replaced the thermostat, are you sure you plugged the sensor back in completely?
Go methodically back through your work, and make sure you didn't miss anything obvious. Then double check all your connections, and try again.
SoundMessage
Dec 5, 2019 10:47 AM
tkenupp
Jan 31, 2018 07:41 AM
richard2008
Sep 26, 2014 02:24 PM
spetznaz
Jun 13, 2013 12:57 PM
