Nankang Tires
Old Aug 25, 2021 | 07:04 AM
scubus's Avatar
scubus
Nankang Tires
My 2005 S has a set of Nankang (Nankang Noble Sport NS-EO) tires on it - they were on it when purchased. I plan to replace them with a set of Pilots, but my questions is how rushed should I be to make the change? They have almost full tread left. I don't know much about Nankang except they aren't top tier, but how "low tier" are they?
Just trying to plan my upgrades and can't afford to do them all at once.
Old Aug 25, 2021 | 07:18 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
What is your driving style, or vehicle use? Daily driver? Weekend warrior?
If daily driver, and the tires don't handle terrible, I would run them until they get worn out a bit, then replace them. Looks like they have a treadwear rating of ~240-ish, so it shouldn't take too long to wear them out.
Old Aug 25, 2021 | 07:39 AM
scubus's Avatar
scubus
Fair question.
I don't have a daily driver - I am fortunate to have a Jeep, a Kona and my Mini and they share daily duty. When I drive the Mini it is always a "spirited" drive to work. I also drive it a lot on weekends and drive it hard, but no track type events.
I did finally manage to have a successful search on NAM and they don't seem to rate too poorly by most accounts.
Old Aug 26, 2021 | 02:43 AM
mountainhorse's Avatar
mountainhorse
What are the dot date codes on the tires ??
https://m.tirerack.com/tires/tiretec....jsp?techid=11
Old Aug 26, 2021 | 06:25 AM
cooper48's Avatar
cooper48
I've found Korean brands to be perfectly acceptable. I run Crugens on my Mercedes SUV for the last few years and they've been great tires.
Old Aug 26, 2021 | 06:44 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I've run Kuhmo's on multiple vehicles, and never had a complaint.
Funny, on the sidewall of my current Kuhmo PS31s it says "Engineered by Korea" - note, not "IN" Korea, but "BY" Korea!
Old Aug 26, 2021 | 06:56 AM
scubus's Avatar
scubus
These are actually Taiwanese but based on the reviews here and the fact a number of people use them on track, and the fact these are nearly new, I have decided to buy a Forge intercooler and run these for awhile
Old Aug 26, 2021 | 09:40 AM
mountainhorse
The Nankang tires are also part of the Yokohama "umbrella" of tires....
Curious on the date codes as that model of tire is no longer made.
I've had great luck with the Nankang... and rate them at least with the Kumho tires.... with the NS-25's as good or better than most on the market UHPAS tires in terms of traction and durability.
Old Aug 26, 2021 | 09:54 AM
scubus's Avatar
scubus
I don't have Scooter here at work, but I'll look when I get home. I am curious as well.
Old Sep 6, 2021 | 06:57 PM
mountainhorse
Did you find the date codes??
Old Sep 6, 2021 | 07:10 PM
scubus's Avatar
scubus
I did... 2014. I am having Pilot Sports put on Thursday.
Old Sep 12, 2021 | 04:47 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Yes, check the four digit date code on the tire sidewall. Check each one since they may have different dates. First two numbers are the week and last two the year of manufacture. Old tire rubber gets hard and hardly wears but is noisy and doesn't give much traction.
Tread depth is one measure of tire life but the date is an important factor. Tires last about 5-6 years usable.
Off brand tires are usually budget and aren't good, switching to Michelin will be much better in every way except your pocketbook.
ZeroKelvin
GP Talk
51
Jun 12, 2013 12:42 PM
tiagosalvador
Nov 28, 2012 10:02 PM
jibeho
Tires, Wheels, & Brakes
Mar 19, 2007 12:26 AM
mini freak
Feb 21, 2007 07:54 PM
rafthos
Apr 19, 2006 07:00 PM
