Cranking but not starting after long storage?
Old Aug 7, 2021 | 11:51 PM
jjchien's Avatar
jjchien
Hi all, really hoping your experience and knowledge can help me! I started to have issues starting my 2007 r56 Mini Cooper S about 2-3 years ago. Brought it to the Mini dealer, and it was diagnosed with HPFP failure. I bought a used HPFP on ebay from a 2009 Mini, and it worked fine for another 9 months, but then I started having starting problems again. I would have to start it 3 to 5 times in the morning before it would idle smoothly without stalling. One day I had to start it 20 times to get it running, so I stored the car for 18 months thinking I would need another expensive HPFP. This week I finally bought a new OEM HPFP from ECS tuning and installed it, charged up the dead battery, but now it is cranking over and over but not starting. It doesn't even ignite to a rough idle or stall. I don't see a check engine light, and the Autophix 5900 I am using is not reading any relevant fault codes. Once I did see an exclamation mark symbol. I know I was stupid for leaving the car stored so long, but didn't need the vehicle working from home. Does anyone have suggestions for what I should check? did I flood the engine, is the battery too weak, are the spark plugs bad or should I drain out the old 18-month old gas? Hoping not to have to tow it to the dealer and face an impossibly high repair bill.
Old Aug 8, 2021 | 02:16 PM
cooper48's Avatar
cooper48
Step 1 -- check for spark at the number one plug. Remove the HT lead and ground it against metal (stick a screwdriver inside it and touch the shock tower), turn it over and see if you're generating electricity. Step 2 (if Step 1 is OK) -- check for pressure at the fuel rail. There's a Schrader valve at the end (similar to a bicycle tube) -- remove the cap and hold a rag there while cranking. That will tell you whether or not fuel is being delivered to the injectors.
Old Aug 8, 2021 | 03:05 PM
jjchien's Avatar
jjchien
Cooper48, thank you for responding! Sorry to sound like a complete noob, but that's how I would describe myself. Could you tell me which cylinder is number 1, and which area I will find the Schrader valve? I took a look around but could not locate it. Here is a picture of my engine bay.
Old Aug 8, 2021 | 03:22 PM
jjchien's Avatar
jjchien
Okay, I Googled and found that cylinder 1 is the far left. Could you tell me what you mean by the HT lead, which hole is it? I have an old voltmeter, would that help instead of touching a screwdriver? Sorry I don't really know how to use the voltmeter. I assume I set it to DC 50v? What could I do with the red and black leads?
Also, I Googled and found that the turbocharged mini Cooper S does not have a Schrader valve fuel test port... I have an Autophix 5900 scanner for BMW and mini, will that tell me fuel pressure?
Old Aug 8, 2021 | 05:03 PM
cooper48's Avatar
cooper48
HT lead = high tension lead (spark plug wire). I drive an R53 so it's different than your engine. You have individual coil packs (one per cylinder), rather than a single coil like my 2004. Unfortunately, I'm not familiar with your newer engine though the fuel/spark functions are not dissimilar. I'm sure there are R56 owner/mechanics on the forum that can provide the information you need. Wait for some R56 owners to weigh in.
Also, this thread may help you: https://www.northamericanmotoring.co...not-start.html
Old Aug 8, 2021 | 06:55 PM
MVPeters's Avatar
MVPeters
Quite frankly & with respect, I'd suggest you find a local mobile mechanic or MINI independent garage or even AAA to get it running or we could be here all night!
Your code reader may be a big help to them. My guess is just bad gas, modern low-grade fuels don't last for more than a few months. Don't waste $$ on 'stabilizers', just use the best gas you can get, it's ethanol-free. A generous dose of injector cleaner is probably wise.
Once it's running, it needs re-commissioning, a couple of decent runs, check the tires, change the filter & oil & fill with top-grade gas.
..... & then use it!
Old Aug 8, 2021 | 07:36 PM
jjchien's Avatar
jjchien
MVPeters, thanks for your suggestions. I asked one mechanic I knew if he would come diagnose at my home but haven't gotten a reply yet, might need to look harder for a good mobile mechanic. It might be bad gas, unfortunately my gas tank's almost full, I will have to Google how to drain out the gas and put in newer good gas. But it could easily be something else, it wasn't starting already before I stored it. I just want to rule out anything I can check myself before resorting to towing it to an indepemdent garage, I live pretty far away from the ones I know.
Old Aug 8, 2021 | 08:02 PM
MVPeters's Avatar
MVPeters
Installing MINI fuel pumps can be tricky, so it's possible that's where the issue is. But where will you put 8-10 gallons of gas at home? Think of all the $$$ you've saved over 18 months - it's worth some professional help, in my opinion. Where are you located?
Old Aug 8, 2021 | 08:23 PM
jjchien's Avatar
jjchien
Funny enough, I happen to have two empty 5-gallon gas Jerry cans in my garage. This is actually the second time I've replaced the HPFP following the instructions on Pelican parts website and watching a few YouTube videos. It doesn't seem that complicated, after unplugging a few electrical clips and taking off the air hoses, it is just disconnecting two fuel lines and 3 torx screws. (then again, it's not starting, so I could have messed up something). The in-tank low pressure fuel pump seems trickier, and I wouldn't want to deal with the fumes. But I was really hoping to feel that sense of accomplishment from solving the problem and fixing it myself! I was so proud of myself for successfully taking apart my car door and replacing a window regulator. It's hard to describe the disappointment I felt when the car wouldn't start after I dropped almost $650 US on the new HPFP and installed it. I am located in North Surrey, BC, Canada.
Old Mar 3, 2022 | 12:26 PM
jjchien's Avatar
jjchien
Success!
Hooray! Just wanted to document this in case anyone else is having similar issues. It was the battery. Even though the battery was pretty new, a 2-year old OEM battery purchased from Mini, it didn't like being dead for long periods and charging it did not revive it enough. I swapped out the battery for a new Costco Kirkland one (cheaper but much higher CCA rating), and it started up on the second try. It idled roughly at first, but got better after a few seconds. So it turns out that 18-month "bad" gas may not run great, but it won't prevent your car from starting. I wish I knew this earlier, because I tried to siphon the gas from the tank with a thin hose, but it got blocked by the anti-siphon device, and I must have damaged the anti-siphon device because now when I fill up gas, the pump stops at every 2 litres or so, and I have to re-squeeze the trigger. This is annoying and potentially dangerous, as I have to keep track of how empty the tank was so that I don't overfill. Does anyone know what the anti-siphon device looks like, and how I might be able to get it back to normal? I imagine it's not going to be an easy thing to replace.
Black Sharpie
R58 :: Coupé Talk (2012+)
Jul 21, 2019 11:00 PM
RCBound
May 7, 2018 06:03 AM
Nealuss
Mar 24, 2015 04:51 PM
Guthrie
Jun 18, 2012 04:24 PM
AJK
Jan 1, 2012 11:53 AM
