New Rims for Winter Tires will they work?
Old Aug 4, 2021 | 03:10 PM
LEGage's Avatar
LEGage
Hello All,
We Just purchased a used 2019 Mini Cooper. I live in MA. We got rid of our 2003 SAAB 9-3. Just a few years ago we purchased new winter tires. So I have
215/55 R16 Blizzaks with just 4000 miles on the tires. Like new.
I did my research I purchased a set of rims that will hopefully work with the tires
Rim size 16x7.5 +45
Backspacing: 6.02
Offset: +45
Wheel Diameter: 16
Wheel Width: 7.5
Hub Bore: 66.60
Bolt Patterns: 5x112
I realize according to some online tire/rim calculators the over size may make the speedometer over by 1-2 mph.
Just looking for people who are familiar with this car and trying see if there is something I was not aware of and missed?
I realize this is wider rim by 1", but have seen other Coopers with wide rims.
Thank you in advance,
Larry
Old Sep 8, 2021 | 05:04 PM
LannyMCS's Avatar
LannyMCS
Yes, they'll work. They're a little larger OD than stock as you've noted, and wider as well which isn't ideal for winter tires, generally you want to go narrower, but they'll still be a huge improvement in the snow compared to whatever factory all-season you've got.
Old Sep 8, 2021 | 07:02 PM
LEGage's Avatar
LEGage
Thank you.
i do realize the wider tire reduces the pound force per square inch on tire contact patch. Ideal would be a slimmer tire for winter tire. Again just trying to milk the set of tires we already have. Also the wider tire will be a bit of an experiment.
The softer winter tire rubber is like first class in a plane on the Seinfeld show. Once you experienced it, it is hard to not travel that way.
Thank you for the verification on the specs. Had no clue about the back side clearance or clearance on the brakes.
Thank you.
Old Sep 9, 2021 | 09:44 AM
Tio Barry's Avatar
Tio Barry
Also. Make sure the lug bolts have sufficient length to properly engage the hub holes. I got similar wheels (I think they were from a Mercedes C) some yers ago and had to buy longer lugs to mount them securely.
Old Sep 9, 2021 | 09:59 AM
MVPeters's Avatar
MVPeters
I'd get one mounted, test fit it on the front & rear, put some weight on it & check the steering.
I think you'll be OK.
Old Sep 9, 2021 | 12:52 PM
LannyMCS's Avatar
LannyMCS
I'm running 18x8 +45 with 225/40/18 and lowered with JCW Pro coilovers and no rubbing.
What rims did you get?
hori
Tires, Wheels, & Brakes
Apr 13, 2013 12:26 AM
thrash0249
Sep 19, 2012 08:58 AM
Funsize Clubman
Aug 19, 2012 01:26 AM
myla2003
Jan 31, 2010 05:14 PM
kyle00
Feb 15, 2006 11:11 PM
