R55 Water in Oil
Old Aug 2, 2021 | 12:39 PM
laurel51's Avatar
laurel51
Water in Oil
Had good luck in finishing the Axle/CV joint!! Now, 2 days later it starts to run very odd & when I pull over to see whatever, I see the water tank empty & the oil dip stick an odd color and way too full~ Never overheated, but what elst but a head gasket
Old Aug 2, 2021 | 03:20 PM
laurel51's Avatar
laurel51
Well, got it home in the driveway for 75 bucks, just don't feel like looking at it 'cause it's been too much trouble this summer. Can't even do a compression test with those plugs!!
Old Aug 3, 2021 | 06:51 AM
e24mpwr's Avatar
e24mpwr
There's not a ton of traffic here - you might want to try R56 as well.
But it definitely sounds like a head gasket... :(
Old Aug 3, 2021 | 05:12 PM
GaPorras's Avatar
GaPorras
Turbo? If so, get the oil out and flush with fresh oil asap.
Old Aug 3, 2021 | 05:14 PM
e24mpwr's Avatar
e24mpwr
For sure - it might be futile, but it's a good idea to have a fresh, controlled data point.
Old Aug 4, 2021 | 07:15 AM
laurel51's Avatar
laurel51
Not a turbo, but, being it ran a couple miles with the water/antifreeze in the oil is there any way to clean it out without a total engine removal & disassemble? It has always used a LOT of oil so maybe this is a good reason to go thru it, but I really don't want to~
Old Aug 4, 2021 | 08:37 PM
GaPorras's Avatar
GaPorras
Drain And use an air compressor to push bad oil through lines. You can drop the oil pan and use brake cleaner to clean all reachable affected areas. You can Refill with cheap oil and run at idle only for a few minutes. Start the process one more time. Don't rev the motor much as the crank bearings literally float on a thin pad of oil via hydraulic pressure.
Here is a link to someone else who had a similar problem on this site. It had some good info.
https://www.northamericanmotoring.co...ad-gasket.html
megaDan
Aug 1, 2021 08:20 AM
redlinealley
Jan 9, 2019 05:12 AM
SeanKidd
Jun 27, 2018 05:44 PM
stripes03
Mar 27, 2012 01:28 AM
