R50/53 Necessary to lubricate axle seals before driving them in?
Old Jul 20, 2021 | 10:16 PM
pollito's Avatar
pollito
Hi all,
i noticed my driver side axle seal is leaking and I have a replacement. I have a scrap transmission i used to test driving the seal with some pvc parts I bought at Home Depot, and it went in fine, but is it smart to add a slight amount of gear oil to avoid anything tearing when driving in? The mating surface of the seal is rubber and has small ridges. I’m not sure if driving it in dry could tear them up and affect its tolerance. Thanks!
Also, I read in the Bentley manual that the metal ring on the axle shaft that seats in the transmission should be replaced If the axle is removed and reinstalled. Do you guys find this to be truly necessary? The axles only have about 5k on them.
Old Jul 20, 2021 | 11:59 PM
OCR's Avatar
OCR
Sure...
Same as filling the oil filter housing before installing the housing cover. It gets oil flowing quicker.
A dry seal, isn't a happy seal..!
Mike
Old Jul 21, 2021 | 01:16 PM
mrbean's Avatar
mrbean
1. I agree, lube the seal.
2. I've always replaced the ring and never had a problem. I've heard anecdotally that the axle can pop out of the trans if it's not replaced, however I cannot confirm this.
Old Jul 21, 2021 | 03:16 PM
cooper48's Avatar
cooper48
I've had axles on my '04 in and out with the same seals with absolutely no problems.
Old Jul 21, 2021 | 04:10 PM
pollito's Avatar
pollito
Thanks for the replies everyone. Appreciate the input!
nellis003
Mar 16, 2019 08:21 PM
AoxoMoxoA
Oct 14, 2018 09:17 AM
QA2
Aug 1, 2018 07:25 PM
AoxoMoxoA
Dec 18, 2017 12:50 PM
