F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 skipping
Old Jul 19, 2021 | 11:49 AM
EmedpaDHSc's Avatar
EmedpaDHSc
Lightbulb skipping
So recently my engine has felt like it is skipping with hard acceleration when passing at freeway speeds. More likely to be electrical(plugs/wires) or fuel injectors/filters? At 60,000 miles.
Old Jul 19, 2021 | 12:14 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
When have the spark plugs been replaced?
Old Jul 19, 2021 | 12:51 PM
EmedpaDHSc's Avatar
EmedpaDHSc
I don't think they have been. I got the car at 23,000 miles as a preowned certified car. It is getting its 60,000 mile tuneup tomorrow. I will ask them to do plugs/wires then if it is not part of the service.
Old Jul 19, 2021 | 03:44 PM
TVPostSound's Avatar
TVPostSound
High pressure fuel pump failure causes this too.
Old Jul 19, 2021 | 04:05 PM
EmedpaDHSc's Avatar
EmedpaDHSc
good to know, thanks!
Old Jul 21, 2021 | 07:28 PM
EmedpaDHSc's Avatar
EmedpaDHSc
it was the plugs. replaced them and problem gone.
Old Jul 22, 2021 | 11:37 AM
TheBigNewt's Avatar
TheBigNewt
High pressure fuel pump problems is almost always difficulty in starting the car.
Old Jul 22, 2021 | 11:51 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I didn't think the 3rd gen engines had fuel pump issues...
Old Jan 27, 2022 | 05:26 PM
EmedpaDHSc's Avatar
EmedpaDHSc
So this happened again at 63, 65, and 68 thousand miles(with new plugs each time...) . Mini now says it is the dinan sport module causing the spark plugs to become worn too quickly. Removed it today and will see if the problem is truly solved now.
Old Jan 30, 2022 | 06:29 AM
gearhead60's Avatar
gearhead60
From: Manassas, VA where the Civil War resides.....
My Dinantronix was giving me a CEL and putting me in limp mode. Had to pull it. Problem fixed.....
Old Feb 4, 2022 | 11:42 AM
WhatV8's Avatar
WhatV8
Interesting. I can believe the worn spark plugs at 60K, but the repeated short term replacement seems a bit odd. I know the added boost puts additional 'strain' on the ignition system to jump the spark gap, but enough to wear out the electrode(s) in 2-3K miles sounds fishy to me. The higher the cylinder pressure, the higher the resistance of the air gap. It would be interesting to have them gap the plugs a little tighter and see if the wear issue goes away or at least comes back into a more 'normal' range. I am speaking from experience with my Mustang over the past 30 years playing around with its boost levels and a much less sophisticated ignition system. Crank the boost with that engine and you have to close up the plug gap to ensure a strong enough spark to light the fire.
Old Feb 23, 2022 | 03:01 PM
EmedpaDHSc's Avatar
EmedpaDHSc
problem seems to be resolved now. I may try the dinan sport again at sport level only(was previously on Race) and see if that is ok.
Old Feb 10, 2023 | 11:08 AM
Eric_Rowland's Avatar
Eric_Rowland
Good to hear. Our F54 just started that at 57K. Hope the plugs resolve it, leaving on a 1K mile trip tomorrow!
Old Feb 14, 2023 | 07:17 PM
EmedpaDHSc's Avatar
EmedpaDHSc
Long term follow up. It was the octane booster destroying the plugs, not the dinan. Stopped using it and at 86,000 miles now with no recurrence. Planning to put the NM engineering unit on soon at the lowest setting so I don't have to use octane booster...
Old Feb 20, 2023 | 12:42 PM
Eric_Rowland
FWIW, replaced the plugs and road trip went off without issue.
Tombstone
Nov 15, 2019 07:44 PM
KinetechMW
Sep 10, 2015 03:12 PM
minicoopermike
Factory JCW Talk (2009+)
Feb 16, 2013 03:28 PM
inmimini
Aug 29, 2005 08:32 PM
johnD
Feb 28, 2005 06:24 AM
