R50/53 please help strange wiper issue not the ground
Old Jul 9, 2021 | 08:06 AM
frankiev's Avatar
frankiev
My wipers will only work on high and on pulse and won't park . I just changed the wiper stalk with a new one and still have the same issue. It can't be the ground or motor because the wipers work. Any help greatly appreciated
Old Jul 9, 2021 | 09:39 AM
MVPeters's Avatar
MVPeters
Sounds like a loose or corroded plug to me, probably the motor one. You are losing power on the low & park circuits.
Old Jul 9, 2021 | 11:33 AM
frankiev's Avatar
frankiev
Thanks for the reply..Do you know if the plug is easy to get to or do I need to remove the motor
Old Jul 9, 2021 | 12:48 PM
MVPeters's Avatar
MVPeters
It's behind the linkage, but I think you can get to it.
Old Jul 9, 2021 | 03:45 PM
BoostedBlueToyotas's Avatar
BoostedBlueToyotas
When I had a problem with wipers not parking it was because I nicked a wire from the wiper motor harness. The harness comes over to
the main wiring loom (going into the cabin) by the brake booster. I was messing around pulling a wire thru the firewall and managed to damage the wire. I think this wire is looped on top of the harness so its easy to snag :(
Old Jul 9, 2021 | 05:19 PM
frankiev's Avatar
frankiev
Much appreciated . I'll work on this after the weekend
Old Apr 12, 2023 | 02:18 PM
bugeye1031's Avatar
bugeye1031
Moderator
Did you ever find your problem?
Old Apr 12, 2023 | 03:34 PM
frankiev's Avatar
frankiev
No I didn't. I tried taking apart the wiper stalk and cleaning the insides but no luck . They work on high so I'm just living with it .
Jlobb2
Jan 15, 2014 10:49 PM
Terry Gallentine
Sep 8, 2011 03:54 PM
Monk Edsel
Jan 18, 2009 06:34 AM
holdenontoit
Jan 7, 2006 08:37 AM
