No crank and foot error icon?
Old Jul 9, 2021 | 06:18 AM
idickers's Avatar
idickers
Last night my 2009 Clubman S with 6-speed would not start when coming home from work. There is no cranking at all, although the battery and electronics are fine. I can get the dash to turn on, and could pull codes. Nothing came up that would explain the no-crank. While fiddling with the car in the dark parking lot, I briefly got an icon for a foot on a pedal, but I only saw it once and can't find the icon in any online searches.
Could this icon be for the clutch safety switch? Or is there another common problem that could lead to this problem? I've heard the starter could be the cause, but I've always heard dying starters at least try to crank, and in fact replaced this starter 4 months ago.
Thanks for any thoughts.
Old Jul 9, 2021 | 11:23 AM
mrbean's Avatar
mrbean
Yes, it sounds like the clutch interlock. It's a magnetic switch on the side of the master cylinder, the blue/black wire is the one that sends a signal to the CAS which determines if the engine is allowed to start.
If the switch isn't defective then perhaps the magnet inside the MC is dislodged and not triggering the switch.
If you have a good scan tool you can connect to the CAS and see if it's getting a signal when you push in the clutch. Otherwise, you might have to back-probe the connector on the switch while it's still attached and the ignition is switched on to measure the signals (no easy task given its location and the fact that you'll need 3 hands to do it).
Wes13coupe
Oct 24, 2020 05:15 PM
WIPMini
Dec 27, 2019 06:51 AM
Thehive
Dec 2, 2019 01:36 PM
Sazxus
Dec 16, 2010 05:37 PM
Lolo
Feb 12, 2003 09:57 AM
