Front wheel hub stuck on axle
Old Jun 24, 2021 | 03:54 PM
MassMini's Avatar
MassMini
Replacing noisy front right wheel bearing on my 2005 Cooper S Cabrio. No problem removing the 4 bolts that hold wheel hub to knuckle and hub separated from knuckle easily. But I can't get the hub off the axle. Seems frozen to the splines. Broke my cheap 3 jaw HF puller. Rented a better puller (rated 4 tons) and that broke too. Soaked it for days with PB blaster but it really doesn't want to budge. Advice appreciated.
Old Jun 24, 2021 | 05:24 PM
minidd99's Avatar
minidd99
If I was you I would try heat. That has always worked for me. Be careful though.
Old Jun 24, 2021 | 06:30 PM
jjcsnlynn's Avatar
jjcsnlynn
You need an air hammer with a pointed tip. Put it right in the center and hammer until it breaks free.
Old Jun 27, 2021 | 06:55 AM
mrbean's Avatar
mrbean
Mine was stuck so bad I had to remove the entire axle and steering knuckle as one piece and put it in a hydraulic shop press. Man,that bugger was stuck in there good.
Old Jul 2, 2021 | 09:53 AM
Jordan Smythe's Avatar
Jordan Smythe
Had to use a wheel puller on the last one I pulled to get the axel freed up, then a 3lb ball peen hammer to knock it loose. All after dousing it with PB Blaster, and letting it sit for a few hours.
Old Aug 6, 2021 | 09:05 PM
MassMini's Avatar
MassMini
Epilogue: Had to heat wheel hub with a torch and use a 10 ton hydraulic puller (from Harbor Freight) to get it off. Destroyed speed sensor in the process. Also had to clean the axle spline grooves with a file to get new hub on, Job was a bit of a PITA. Nice and quiet now though.
Old Aug 27, 2025 | 01:18 PM
pkgmSu2000's Avatar
pkgmSu2000
I can get NEW Detroit axle front and rear rotors really cheap. $25 each. Are their rotors crap or decent or actually pretty good?
sawicki
Aug 14, 2019 02:55 PM
Kingerbeerman
Apr 27, 2014 04:55 PM
mini_rover
Jan 14, 2014 05:51 AM
scott_roberts
19
May 24, 2008 05:01 AM
