Does anyone know how to test the wiring to the Mass Air Flow sensor?
Old Jun 8, 2021 | 10:16 AM
tjkru's Avatar
tjkru
I am still getting a Mass Air Flow code on my 09 Clubman (non-turbo) after changing the Mass Aire Flow sensor. Anyone know how to test the wiring between it and the computer? Can I do this with a multimeter? If this can be done with a Foxwell scanner what options do I need to select?
Old Jun 10, 2021 | 07:40 PM
Briscoec's Avatar
Briscoec
TJ, where did you buy the new MAF from. Not ebay, hopefully. I made that mistake. I replaced it with a Bosch ($250 ish), not OEM (nearly $400).
Old Jun 10, 2021 | 07:48 PM
Briscoec's Avatar
Briscoec
I meant to add. After I replaced MAF (with Ebay) I chased my tail for days on the way care ran. I took it to the dealer in Houston and their techs couldn't even check it. They had a used car with same engine set up and swapped parts and it ran like a dream. Because they kept it for so long for trouble shooting and since they didn't have a replacement in stock $526, they didn't charge me. Wow. Very impressed at the N/C.
Old Jun 11, 2021 | 06:11 AM
tjkru's Avatar
tjkru
I purchased a Bosch from Auto Zone. all of my parts have been Bosch or original manufacture. Nothing from questionable sources like EBay. I have another thread where I was chasing a low power motor and this is all that is left. Fixed the throttle (replaced and reprogramed, replaced the differential pressure sensor eliminating those codes, replaced the water temp sensor, now the fan turns off properly. Cleaned the VANOS sensors to remove the code regarding those. Also did the normal oil, air filter and plugs. I doubt it is a coil since there is no misfire codes associated with any single one. 90 octane fresh gas.
The Foxwell scanner mentions Mass Air or DZM (sp?). I kind of doubt the computer since this is the only code left. Would like to check the communication between them.
Old Aug 20, 2021 | 07:19 AM
tjkru's Avatar
tjkru
Wiring was fine. The second cat was partially clogged causing the code to be thrown.
Old Dec 5, 2023 | 01:42 PM
SpencerT's Avatar
SpencerT
I’m kinda having the same issue but I don’t know how to check the wiring
tjkru
May 28, 2021 09:00 AM
Rewind
Feb 9, 2021 04:36 PM
wertslj
Sep 1, 2018 01:48 PM
GAT
Apr 13, 2016 04:53 AM
Bob Stephens
Jul 15, 2008 07:56 PM
