R50/53 ABS Wheel speed sensor for R53
Old May 30, 2021 | 03:00 PM
Tombstone's Avatar
Tombstone
How many wheel speed sensors does an 2006 R53 have ;found two : was only drivers-side front & passenger -side rear? Thanks...
Old May 30, 2021 | 03:11 PM
deepgrey's Avatar
deepgrey
Four.
Old May 30, 2021 | 04:02 PM
Tombstone's Avatar
Tombstone
Thanks Deep Grey...
Old May 30, 2021 | 06:30 PM
jjcsnlynn's Avatar
jjcsnlynn
I recently read the 2002-2003 models only had two but I can’t confirm that.
Old May 31, 2021 | 08:25 PM
analyte's Avatar
analyte
My 2003 MCS (built 12/02), has 4 ABS sensors.
Based on the OP's description of left front and passenger rear, he may have been looking at the brake pad sensors.
Old Jun 1, 2021 | 05:55 PM
Tombstone's Avatar
Tombstone
I know the difference between brake pad sensors and ABS sensors ; already replaced right-rear sensor & all the pads /rotors / plus upgraded to JCW (R56) calipers but, still did not correct the Trifecta.
Old Jun 1, 2021 | 06:14 PM
analyte's Avatar
analyte
Sorry, I didn't mean to offend. I was just trying to help.
Is it dropping any codes along with the fault lights? My ABS sensor went bad, and when I scanned the car the reader noted it as front left. Just checking.
Old Jun 1, 2021 | 06:29 PM
Tombstone's Avatar
Tombstone
No problem , the scanner I am using is a
Professional BMW/MINI/Rolls Royce Elite Scan Tool but, it does not indicate which side ABS sensor is bad? I think Foxwell makes this tool.
Old Jun 4, 2021 | 11:03 AM
adriancl's Avatar
adriancl
Lokk on live data , will see wich sensor is bad.
Old Jun 5, 2021 | 05:31 AM
Grand-Cayman's Avatar
Grand-Cayman
My 2006 R53 JCW has four, 100% positive.
Old Jun 7, 2021 | 05:36 PM
Tombstone's Avatar
Tombstone
Finally able to figure out the Foxwell NT 510 for testing all four ABS sensors (live data all tested good). Reset Steering Angle Sensor to 0 -degrees turning off TPMS light. Only thing still lit is the DSC/ASC light which indicates code 5E1 6/NOT PRESENT, which is the DSC module.
Old Jun 7, 2021 | 05:49 PM
jjcsnlynn's Avatar
jjcsnlynn
You can change that module without removing the mechanical side of the ABS module. It saves a lot of work. Three screws the connector is all. They are $30 used on eBay if you need ti go inexpensive.
Old Jun 7, 2021 | 08:34 PM
Tombstone's Avatar
Tombstone
Wow, that sounds like the way to go . Thanks for the tip...👍
Old Jul 5, 2021 | 10:22 AM
Tombstone's Avatar
Tombstone
Four , you are correct. Thanks ...
JP-Oh
Apr 26, 2021 08:03 AM
chefmike71
Oct 29, 2017 08:44 PM
SooperCoopers
Jun 9, 2016 01:46 PM
tylerc
Apr 19, 2016 01:01 PM
quickslvr580
Dec 12, 2012 01:58 PM
