Replacing Outside Air Temp Sensor
Old May 26, 2021 | 05:44 PM
Briscoec's Avatar
Briscoec
Question to the forum that seems to have the best answers on the net. I finally saw a how to replace ambient air sensor video and it bent my mind. I just wanted to ask the experts, do I have to remove the front bumper (cover) to access the sensor. Can it be reached by removing the black grill middle grill?
I'm just sayin.... I find it hard to believe German engineering would make it so difficult to replace a sensor. Come on................
Old May 26, 2021 | 08:57 PM
renchjeep's Avatar
renchjeep
I managed to replace the ambient air temp sensor on my wife's 2013 R57 by going under and taking a few of the lower front bumper cover plastic clip-nut things off and bending the bumper cover down a bit, then reaching my hand in there. It was on jackstands for an oil change, so that helped a lot.
Old May 27, 2021 | 08:16 AM
Briscoec's Avatar
Briscoec
I was hoping to try that . Thanks for the response. My ambient sensor is reading 32 (on the live stream). It occasionally gives me a thermostat MAP sensor. I'm still fighting a low rpm misfire that gives a knock sensor error. Changed plugs and coil packs, replaced fuel with higher octane (91). I am wondering if the ambient affect valve body position through MAP IAC sensor.
Old May 28, 2021 | 07:20 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The LCI models have the sensor in a different position than the pre-LCI models. See my post in your other thread.
Old May 28, 2021 | 08:28 AM
Briscoec's Avatar
Briscoec
It is directly behind mid grill.
Thanks, I realized I put thread in wrong forum. BTW, after opening the bottom of the bumper and looking inside, I saw sensor attaches to R side of mid grill. Sweet. Easy replacement. Germans are brilliant.
chez602
20
Jun 28, 2025 07:10 AM
Briscoec
MINI E Talk (2010)
May 28, 2021 09:04 AM
imncrxtc
Jan 19, 2018 03:16 PM
harrisoncope
Dec 19, 2010 07:41 PM
robertpick
Nov 19, 2002 09:28 AM
