F55/F56 Retrofit JCW Steering Wheel with Paddle Shift on Cooper 1.5 LCI
Hey Folks, (Maybe you guys can help... @minicooperjp @DarkMiniCooperS @boubi @ciclo @pinky_chi @Imperial )
I own a Mini Cooper 1.5 Turbo F56 LCI 2019, Automatic Transmission 7-Speed. I have ordered a JCW Steering Wheel with Paddle Shift to replace my stock steering wheel that does not have paddle shifts.
I know I need to do the proper coding to enable the paddle shifts. From what I have researched this is what I need in terms of Coding:
The JCW Steering Wheel that I ordered already comes with the Steering Wheel Wire Set.
My question now is:
Will I need any extra wiring from where the new Steering Wheel to Body Domain Controller (BDC)?
If I need any extra wire, what is exactly what I need? Any one has a diagram that shows what needs to be connected and where?
Regards,
Henrique
1) BDC_BODY -> PADDLES_VERBAULT (set to "aktiv" - default "nicht_aktiv")
2) EGS -> Sport T/M (set to "enabled" - default "disabled")
My question now is:
Regards,
Henrique
My question now is:
Regards,
Henrique
My question now is:
Regards,
Henrique
On the BDC side I still need to figure out where the other end of the wire is connected.
Does anyone here has a wiring sheet of BDC (should be the top row second connector from the right on LHD cars - Brazil steering wheel is on left side)???
I was thinking if I can confirm which is the wire required, I can check if it is already there.
preme123
Nov 10, 2012 09:51 AM
stevepsd
Nov 19, 2011 11:15 PM
Interior/Exterior JCW Fat Steering Wheel w/ Paddles???
BlimeyCabrio
Nov 21, 2006 05:55 AM
