SOLVED! Cranks but Won't Start, P1692 Code
Old Apr 27, 2021 | 07:27 PM
ericfreeman's Avatar
ericfreeman
After replacing the throttle body with no effect (thanks BMW for your great onboard diagnostics) I checked every fuse block and connector for signs of water, mice or other damage. Couldn't find anything. Discovered there was no power to the coil so began checking ECU wiring. Found the Main Relay wasn't getting its triggering ground signal from the ECU. Bypassed the relay and the motor started right up! Discovered the small brown/red wire going from the ECU to the relay socket had no continuity. Began peeling off the cloth harness wrap and about 3 inches from the ECU plug noticed a small pinched section of the wire. Clipped the wire and stripped it back to find about 1/4" of corroded wire. Cut out the bad section, soldered and heat shrunk a new piece of wire in place and I now have continuity! Took 17 years and 210,000 miles for this small wire to fail but I'm glad I found it without further pain. Now I have to put everything I took apart back together!
Lesson of this story is to pretty much ignore what the Diagnostics tell you and don't go throwing parts at the problem ($240 for the throttle body) but carefully check out the wiring system.
Eric
cervantes
Jan 18, 2018 10:33 AM
NFCooper
Electrical
Jun 27, 2007 01:45 AM
2Cool
Feb 2, 2007 10:20 AM
dinile
Aug 16, 2005 03:04 PM
wahwah
Dec 24, 2004 10:18 AM
