R55 clubman build thread
Old Apr 21, 2021 | 03:40 PM
Yoshimura 1's Avatar
Yoshimura 1
My build thread on the R55
Old Apr 21, 2021 | 03:42 PM
Yoshimura 1
Old Apr 21, 2021 | 03:43 PM
Yoshimura 1
Old Apr 21, 2021 | 03:51 PM
Yoshimura 1
This is when I first got the vehicle it was none operational. The car would not start at all with the keys the hood couldn't open
The club door on the passenger side wouldn't open either.
Old Apr 21, 2021 | 03:53 PM
Yoshimura 1
Old Apr 21, 2021 | 03:56 PM
Yoshimura 1
Just a little water on it
Old Apr 22, 2021 | 03:41 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I like the blue. Looks like it just needs to be cleaned up a bit? What's your plan for it?
Old Apr 22, 2021 | 04:28 AM
Yoshimura 1
That was when I first picked it up. It has since got the royal treatment I'll be posting some pic's of the progress.
Old Apr 22, 2021 | 10:49 AM
Yoshimura 1
Old Apr 22, 2021 | 10:56 AM
Yoshimura 1
Chasing a few issues with this car. The shift lock lever by the shifter console was broken this is used in a emergency
situation when your car battery has died and you need to put the vehicle in neutral. You pull up on the yellow piece
very gentle as not to snap it and this will enable you to do so.
Old Apr 22, 2021 | 11:33 AM
Yoshimura 1
Old Apr 22, 2021 | 11:40 AM
Yoshimura 1
Old Apr 22, 2021 | 11:52 AM
Yoshimura 1
Getting ready to remove the head no compression on cylinder #3
Old Apr 22, 2021 | 11:54 AM
Yoshimura 1
Old Apr 22, 2021 | 12:05 PM
Yoshimura 1
A little cleaning up prior going to the shop.
Old Apr 22, 2021 | 12:07 PM
Yoshimura 1
Old Apr 22, 2021 | 12:09 PM
Yoshimura 1
Pics
Old Apr 22, 2021 | 12:27 PM
Yoshimura 1
Old Apr 22, 2021 | 12:30 PM
Yoshimura 1
Looook at all of that muck in the intake manifold
Old Apr 22, 2021 | 12:33 PM
Yoshimura 1
Old Apr 22, 2021 | 12:36 PM
Yoshimura 1
There's the famous throttle body looook with all the muck again
Old Apr 22, 2021 | 12:37 PM
Yoshimura 1
Old Apr 22, 2021 | 12:39 PM
Yoshimura 1
PCV tubing is garbage so brittle and hard cracking into pieces
Old Apr 24, 2021 | 07:03 AM
yeticat99's Avatar
yeticat99
Did you find a broken or bent valve on #3 cylinder? If not, I'd be worried about piston #3. All that muck is also concerning. Did you do a leakdown test before yanking the head?
Old Apr 24, 2021 | 07:48 AM
Yoshimura 1
Absolutely common problem on the exhaust side
As told to me by the machinist.
