F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
JCW Rear Wipers Out of Sync 2020 JCW
Old Apr 9, 2021 | 07:12 AM
Matt Burkett's Avatar
Matt Burkett
When I turn the rear wipers on, the passenger side operates as if I had activated the wiper fluid function (without spraying fluid) and then stops in a random location (not in the normal "parked" position). The driver side rear wiper operates normally. Any ideas?
Old Apr 9, 2021 | 08:28 AM
Landspeeder's Avatar
Landspeeder
Matt, Place a call to your MINI dealer and have them check to see if your car has a recall notice. My '19 was affected by a 'body control module' issue that affected all electronics except engine/transmission. Nothing was wrong that I could tell but was taken care of when I had my recent service visit. I believe they flash the modules of concern to the factory (new) default settings. If you have been 'modding' your car - programming or making changes to any part of the wiring or controls - you may have accidentally kicked off the symptoms you are experiencing. Good luck with your detective work.
Old Apr 9, 2021 | 08:30 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I also would give a call to the dealer. A 2020 should still have some kind of warranty left.
Fatandre
Sep 20, 2009 05:43 AM
flav
Jul 14, 2008 10:01 AM
wiglaf39466
May 29, 2008 07:15 AM
skier-clay
Mar 4, 2005 08:09 AM
