R50/53 Screwed up fuel pump / filter change. Where did I go wrong?
Old Apr 2, 2021 | 11:53 AM
rooooney1's Avatar
rooooney1
2003 Mini Cooper base 5 speed.
. So I had a crank no start issue and assumed it was the fuel pump because I couldn't hear it priming. I bought a new pump and filter. Before I took out the old pump I gave it a nice bang or 2 with a hammer. It kicked on and the car started fine after that.
Because I had the new parts though I decided to put them in. I replaced the pump and the filter, seemed pretty easy. After I completed the job I hear the pump loudly prime when I turn the key but she just cranks. I realize the system would need to pressurize but she just cranked and cranked, never fired up. I tied for 5 mins
I noticed lot of plastic components in and under the fuel filter housing, could I have messed something up in there that caused a no start? Sucking in air perhaps? I took both apart 3 times and put back, still just cranking, I even tried putting the old pump in, still just cranks. I'm looking for any ideas, thanks. Fuse under dash looks good too
Old Apr 8, 2021 | 02:14 PM
ssoliman's Avatar
ssoliman
Check to be sure all the sealing surfaces are tight? Also did you mark the cap to get the right torque or did you use a other methods?
I want to say I’ve read that can be a problem...
Calm_batman
Jul 23, 2024 11:16 AM
RKLMINI
Apr 8, 2020 05:58 PM
RKLMINI
Apr 8, 2020 05:42 PM
Brownshoe
14
Apr 6, 2016 07:31 AM
zapola6
Mar 24, 2015 09:24 AM
