Aim Solo DL 2 usage details
Old Mar 25, 2021 | 07:37 AM
DavidPinAZ's Avatar
DavidPinAZ
If you’re planning on purchasing an Aim Solo DL 2 for track telemetry, be aware that it will *not* work with the OBDII port. Ask me how I know (it’s a longish story). What does work is tapping into the CAN wires in the passenger side foot well area. The good news about this is that we can get a *lot* of data from our cars this way.
Data that’s available:
RPM
Gear (Actual gear)
Speed
Separate speed for each wheel
Engine Temp
Oil Temp
Ambient Temp
Gear Temp
Front Brake Pressure (PSI)
Rear Brake Pressure (PSI)
Steering Angle
Throttle
Pedal Position
Engine Load
Gearbox Torque
Engine Torque
Brake (still not sure what this is)
Various G forces
I'm not sure if the the device usage will be the same for our non-GP3 brethren or sisteren.
I have my first track day with the Solo DL 2 this weekend and I’m super excited to see how all this data helps me out!!
Old Apr 11, 2021 | 09:48 PM
Clutch Wotan's Avatar
Clutch Wotan
https://www.me-mo-tec.de/de/Produkte/AIM/Solo/Solo-2-DL
Old May 1, 2021 | 09:46 PM
Svampfest's Avatar
Svampfest
Hi David,
Thanks for the infos. I am planning to install my it on my gp2. Did you take any pictures of CAN cable connections while installing the device ?
Old May 2, 2021 | 08:27 AM
DavidPinAZ's Avatar
DavidPinAZ
Unfortunately, I did not. However, the wiring on the GP3 is *very* different from other Mini's, so it probably wouldn't have helped much anyway. The professional that installed it for me had to do some trial and error to find the right twisted pair. None of the online docs, nor other AiM reps he knew and consulted with knew which twisted pair to use.
Old May 7, 2021 | 07:10 PM
Clutch Wotan
OfferAIM system for VLN endurance racer. The system offers a number of sensors. This customers wants to monitor spring rates.
LIVNLRG
Apr 6, 2019 10:00 AM
gex23
Jan 13, 2019 10:43 AM
MrBlah
Electrical
Oct 26, 2016 04:31 PM
minim8o
Off-Topic :: Autos
Mar 17, 2011 08:25 PM
mbcoops
Driver's School
11
Sep 19, 2007 09:08 PM
