Air Bag Code
Old Mar 24, 2021 | 04:25 PM
fullmoonguru's Avatar
fullmoonguru
Air Bag Code
'06 R53. My red airbag light is on. I read the code with INPA and it's a ZAE2 with a description of "airbag head right". I assume that's the curtain airbag that runs along the top of the passenger side window? It says, "remain over limiting value"
Old Feb 1, 2022 | 11:27 AM
fullmoonguru
Back on this. Really need to get it resolved.
In addition to the ZAE2 code it says:
11 ignition circuit 7 -> airbag head right
Error frequency : 49
Remain over limiting value
I removed the interior panel on the right side of the car, removed the cable to the battery, removed the cable to the airbag, sprayed with electrical cleaner, and reassembled. Cleared the error with INPA but it's still there.
Old Feb 1, 2022 | 06:38 PM
ssoliman's Avatar
ssoliman
What code you have? Maybe post a pic of the inpa screen?
Do u have the wiring diagram? U could take readings at the plug
Old Feb 2, 2022 | 08:33 AM
fullmoonguru
Well I wrote everything in teh code above but I'll post a pic anyway.
I can certainly take readings at the plug but I need to know what I'm looking for. Hoping someone can help with how to diagnose this.
Old Feb 2, 2022 | 07:55 PM
ssoliman's Avatar
ssoliman
There are small resistors you can buy that will keep the error and light out.
id not use those as a permanent fix but it can be a good test. If the error goes away with the right resistance, you know your prob is the airbag…
Old Feb 3, 2022 | 08:44 AM
fullmoonguru
ssoliman, thanks! I didn't see it specifically but I'm assuming the 3.2 ohm resistor will work for the head airbag.
I'm ordering a resistor kit from Amazon with a bunch of different ratings.
Old Aug 14, 2022 | 09:01 AM
fullmoonguru
Resurrecting this thread as I am getting back into this issue. I tried a resister which didn't work but I think the wattage was too low.
Anyway, I need to diagnose this issue and get it resolved finally. I went to the junk yard and cut the wires to the airbag connector and measured resistance. I got 2.2 ohms. So I took that connector to my garage, plugged it into my airbag and got 2.3 ohms. Does anyone know what the tolerance is? Is that .1 ohm causing this error code or am I looking for something else?
I just found a post in this thread that says the range is 1.8 to 4. That's for the seats though. Also I see posts where people say the 3.9 resister didn't work but the 2.2 did.
In any case, I don't need to make the light go off, I actually want to resolve the issue. Any help with troubleshooting this would be appreciated.
Old Dec 22, 2022 | 01:06 PM
Tsiggy's Avatar
Tsiggy
Alliance Member
Wondering if you got to the bottom of things. My '05 R52 just popped the Airbag light on so I made sure to check and charge battery and cables. Light still present as of 1st test drive. I have an OBD scanner on my Santa list so the New Year project is to find the fault. Any help from your experience is appreciated.
Cheers
Old Dec 22, 2022 | 07:32 PM
RB-MINI's Avatar
RB-MINI
Unfortunately no amount of charging, cable checking, even repairing a bad airbag or known issue will make an airbag light go out without actively resetting it with a capable diagnostic tool/scanner or computer program.
One cause could be a faulty passenger seat occupancy sensor which can trigger an airbag light. The first model year for it was 2005. Have you run your VIN on MINI’s website to see if it’s part of the recall for that part? https://www.miniusa.com/owners/tools...rt/recall.html
There was also a power steering pump recall that might include your car.
Old Dec 23, 2022 | 05:54 AM
fullmoonguru
It was teh squib connected to teh battery cable. Cut teh wires, disconnected teh plug, soldered a resister to the wires
Amazon Amazon
reconnected, cleared teh code with INPA.
Old Dec 23, 2022 | 12:11 PM
Tsiggy's Avatar
Tsiggy
Alliance Member
Thanks for quick reply
Santa has put a Scanner in the sleigh for me and I will look closely at the Terminal Squib. You both are kind to reply so quickly and I will report back with the solution found. Cheers
georgia
Jan 15, 2021 05:57 AM
sungjk
Dec 11, 2017 02:37 PM
Grizld700
Aug 28, 2017 10:20 PM
minir53 155
Oct 12, 2014 06:04 AM
Old Smallblock Guy
Nov 13, 2008 12:09 PM
