Looking to Buy '06 R53. Airbag light
Old Aug 28, 2017 | 05:42 AM
Grizld700's Avatar
Grizld700
As the title says, I'm looking at a R53. Only has 44k miles on the Odo. Looks like a minor leak from the rear main seal. But more concerning is the air bag light is on.
I was able to pull codes from the airbag system.
Code 02 - Ignition Circuit ZK1 / Belt Tensioner Driver
Code 88 - Side Airbag Sensor Front Left
Code 05 - Ignition Circuit ZK4 / Side Airbag Front Left
Does this look like someone disconnected something? Or should I be concerned that an Airbag may need to be replaced.
Old Aug 28, 2017 | 06:20 AM
Whine not Walnuts's Avatar
Whine not Walnuts
I know the Gen1s had a passenger side airbag mat sensor recall. I do no know whether that would throw the codes. You should be able to take the VIN and determine whether the recall was performed.
Old Aug 28, 2017 | 06:29 AM
Grizld700's Avatar
Grizld700
It didn't show a recall when i checked safercar.gov :-/
Old Aug 28, 2017 | 06:38 AM
CRC's Avatar
CRC
Try this:
http://www.miniusa.com/content/miniu...rt/recall.html
Old Aug 28, 2017 | 08:38 AM
Grizld700's Avatar
Grizld700
Originally Posted by CRC
As stated in the post above, I already checked for recalls. This does not have an open recall.
Old Aug 28, 2017 | 09:46 AM
Grizld700's Avatar
Grizld700
Also to add, the recall is for the passenger seat occupant sensor. Not the drivers seat, which is what the codes are for.
Old Aug 28, 2017 | 09:47 AM
Noonzio's Avatar
Noonzio
Seat swap?
Old Aug 28, 2017 | 10:01 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
someone probably disconnected the seat and did not know to unhook battery first.
Old Aug 28, 2017 | 11:40 AM
Grizld700's Avatar
Grizld700
K I had the codes cleared and 2 codes came right back.
So disconnected seat is off the board. And swapping seats will only cause the light to come on as the drivers seat does not have a occupant sensor like the passenger side.
Old Aug 28, 2017 | 12:42 PM
MrBlah's Avatar
MrBlah
check to see if it's even hooked up under the seat
Old Aug 28, 2017 | 01:55 PM
Grizld700's Avatar
Grizld700
Yeah been there, done that. Everything is hooked up. Codes wont clear. I suspect the air bag module in the seat or the main SRS control module. I just need to find out how to diagnose which is at fault.
Old Aug 28, 2017 | 10:20 PM
Noonzio's Avatar
Noonzio
Are the seats that are in it the original seats??
