R50/53 Maintenance
Old Mar 16, 2021 | 11:50 AM
MyminicooperS's Avatar
MyminicooperS
Maintenance
Hello,
I will be removing my subframe to change the lower control arm bushing plus power steering pressure hose. Is there anything else I should change while I have the subframe down?
Thank you in advance
Old Mar 16, 2021 | 12:04 PM
deepgrey's Avatar
deepgrey
The sway bar and steering rack bushings are really only accessible with the subframe out.
Old Mar 16, 2021 | 12:29 PM
MyminicooperS
Thanks, deepgrey
I will change out the bushing
Old Mar 16, 2021 | 06:24 PM
Racingguy04's Avatar
Racingguy04
I would replace the inner ball joints, steering rack bushing, and sway bar bushings in addition to the control arm bushings.
Old Mar 17, 2021 | 07:27 AM
MyminicooperS
Thanks for the suggestion Racinguy04
Old Mar 21, 2021 | 07:18 PM
ssoliman's Avatar
ssoliman
All bushings and ball joints for sure.
maybe the oil filter housing gasket? I can’t remember now if that is easier with the subframe out, I’d think so.
good time to do tie rods also if you need them
Old Mar 23, 2021 | 11:37 AM
MyminicooperS
Thanks, ssoliman
I will add oil filter housing gasket to my list
Old Mar 23, 2021 | 06:38 PM
Mini Devil's Avatar
Mini Devil
Correct me if I'm wrong here. Can't this be done without dropping the SF? I only ask because I'm about to do mine as well
Old Mar 24, 2021 | 11:39 AM
MyminicooperS
I believe you can do it without drop the SF. Have you see this video before ..........
Old Mar 25, 2021 | 06:33 AM
Mini Devil's Avatar
Mini Devil
Originally Posted by MyminicooperS
I believe you can do it without drop the SF. Have you see this video before ..........https://www.youtube.com/watch?v=RxI5...DVJ2h&index=27
I've done my oil cooler already, without dropping the SF. I was referring to the tie rods
Kitchenboy
Mar 21, 2020 06:14 PM
jamfred774
Sep 26, 2014 06:01 AM
Patas
Jun 27, 2014 01:48 PM
Drunktank
Jan 3, 2013 08:58 PM
meb
Suspension
16
Oct 26, 2009 08:55 PM
