R50/53 AIRBAG RESISTOR Aftermarket Seats
Old Mar 4, 2021 | 04:37 AM
Serafin's Avatar
Serafin
Hello. I’m sure this has been covered. But i can’t seem to find a current / updated link.
is there a plug and play resistor for the airbags instead of soldering one for the r53 airbag ?
upgrading my seats soon.
Thank You
Old Mar 4, 2021 | 06:49 AM
deepgrey's Avatar
deepgrey
The '06 has to have a special emulator. Supposedly some of them work, but I've never tried.
Old Mar 4, 2021 | 07:13 AM
Serafin's Avatar
Serafin
emulator? You have more info or link? Good to know Thank You
Old Mar 4, 2021 | 10:12 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
it's probably better to code it out of the airbag module with NCSEXPERT, that is what I do with mine
Old Mar 4, 2021 | 10:15 AM
Serafin's Avatar
Serafin
i only have the foxwell abs and srs coder. Will that work?
Old Mar 4, 2021 | 10:19 AM
MrBlah's Avatar
MrBlah
no you need a kcan cable and INPA and ncsexpert working, ncsdummy makes the config edit easier so get that too
Old Mar 4, 2021 | 10:23 AM
Serafin's Avatar
Serafin
oh boy. There’s no way i can even splice the cable from the old seats? There’s gotta be another way
Old Mar 4, 2021 | 10:40 AM
deepgrey's Avatar
deepgrey
You could remove the occupancy sensor from the old seat and hook it up. Coding is possibly easier though. I bought one of those emulators a long time ago when my sensor failed, but I just ended up coding mine out as well before I could try the emulator. I believe it's OC3 in NCSdummy, but it's been a while.
I just realized that you'd have to code out the airbags as well so probably best to just get everything set up for coding. My brain was only half awake when I answered earlier.
Old Mar 4, 2021 | 12:42 PM
Jason Cornelius's Avatar
Jason Cornelius
Contact the boys at Detroit tuning, I think they might have exactly what you need or can point you in the right direction.
Old Mar 4, 2021 | 02:41 PM
Serafin's Avatar
Serafin
thank you
Old Mar 4, 2021 | 02:44 PM
Jason Cornelius
thank you
I might be doing a seat swap myself, but just the driver’s side, however I got a buddy that swaps seat in his R56 and they had what he needed, I think he talks to Chad, but don’t quote me on this one.
Old Mar 4, 2021 | 03:33 PM
Serafin's Avatar
Serafin
ya chad is emailing me something. Waiting for it.
thanks again guys. Will keep this thread posted.
Old Mar 4, 2021 | 05:13 PM
navwizard's Avatar
navwizard
I had an airbag out of my Countryman briefly. I just disconnected the plug and stuck a 3.3 ohm resistor in the pins. Worked fine?
Note: 3.3 ohm, not 3.3k ohm.
Dan
Old Mar 4, 2021 | 05:48 PM
Serafin's Avatar
Serafin
I found this https://www.ebay.com/itm/4PCS-SRS-Ai...Cclp%3A2334524
this should work?
Old Jun 2, 2021 | 04:56 AM
Eurothrasher's Avatar
Eurothrasher
Thank You
I purchased the OEM air bag end of the connectors from Germany and made my own....."plug and play"
Old Jun 2, 2021 | 06:49 AM
Serafin's Avatar
Serafin
Got pics?
you just did a connector with no Resistor?
Old Jun 2, 2021 | 07:02 AM
Eurothrasher
I purchased two MINI wiring "repair kits" for the airbags.
I purchased resistors.
Then soldered the resistor to the two wires coming off that connector.
Then plugged that new connector into the airbag harness for the seat.
When plugged in, the system thinks the airbag is still connected.
Old Jun 2, 2021 | 07:08 AM
Serafin's Avatar
Serafin
YEs, question remains what size Resistor did you use? what years your Mini?
thank you
Old Jun 2, 2021 | 01:09 PM
Eurothrasher
thank you
Just home from work.
Been driving for 7hrs.
Give me a min....Just sat down to eat and haven't had a meal since yesterday.
I think I have left over resistors I can mail you !
Old Jun 4, 2021 | 04:50 AM
Eurothrasher
I looked everywhere for the "leftovers" of the airbag repair kit hoping to get you a part no......I think I may have tossed them away cleaning out some old MINI stuff.
Just go to a MINI parts counter and order up a "repair kit" for the airbag side of that harness.
They cost about $50.00 ea I think but works great for a plug and play set up.
Old Jun 4, 2021 | 05:54 AM
Serafin's Avatar
Serafin
awesome man, thank you and what year is your mini?
Old Jun 4, 2021 | 05:57 AM
Serafin's Avatar
Serafin
Like this https://www.fcpeuro.com/products/bmw...YaAiBAEALw_wcB
Old Jun 4, 2021 | 06:43 AM
Eurothrasher
2003. Its a 3/2003 build.
I can mail these to ya.
Send me your details via pm.
Old Jun 4, 2021 | 06:45 AM
Eurothrasher
MINI kit had wire ties too I think but yes, it's very similar to what you will be asking the parts advisor for.
Old Jun 4, 2021 | 06:47 AM
Eurothrasher
https://www.realoem.com/bmw/enUS/par...q=61129118130+
That part number looks good !
https://www.bmwdirectparts.com/oem-p...13-61129118130
From BMW/MINI Parts hub. $31.50 ea
